I tried this way to position a second calibration sphere from the "master" sphere, it seems to work very fine.
It uses the "calibrate single tip" function.
LOADPROBE/LSPX1_L50_D5 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO, This program is used to reposition a second sphere with respect to the reference sphere. Be careful, it resets the probes. TEMPCOMP/ORIGIN=0,0,0,CTE=0.0000115,Reference Temp=20 ,Hi Threshold=40,Lo Threshold=10 ,PART SENSOR NUM=9 ,X AXIS TEMP=20.7934,Y AXIS TEMP=20.1402,Z AXIS TEMP=20.444,PART TEMP=20.3119 AUTOCALIBRATE/PROBE, PARAMETER_SET=A0B0_master_probe, QUALTOOL_MOVED=YES_DCC, CHECK COLLISION=NO, SHOW_SUMMARY=NO, OVERWRITE_RESULTSFILE=NO ASSIGN/V1=QUALTOOLDATA("xyz","SPH_CMS106") ASSIGN/V2=QUALTOOLDATA("diam","SPH_CMS106") MODE/DCC MOVE/POINT,NORMAL,<V1.X,V1.Y,V1.Z+500> SPH1 =FEAT/CONTACT/SPHERE/DEFAULT,CARTESIAN,OUT,LEAST_SQR THEO/<V1.X,V1.Y,V1.Z>,<0,0,1>,V2 ACTL/<1067.0716,461.2152,-932.6124>,<0,0,1>,25.4598 TARG/<V1.X,V1.Y,V1.Z>,<0,0,1> START ANGLE 1=0,END ANG 1=0 START ANGLE 2=0,END ANG 2=0 ANGLE VEC=<1,0,0> SHOW FEATURE PARAMETERS=NO SHOW CONTACT PARAMETERS=NO MOVE/POINT,NORMAL,<V1.X,V1.Y,V1.Z+500> CALIBRATE ACTIVE TIP WITH FEAT_ID=SPH1, QUALTOOL_ID=SPH_CMS106, MOVED=YES AXIS THEO MEAS DEV STD DEV X <1067.0716 1067.0716 0.0000 Y 461.2152 461.2152 0.0000 Z -932.6124> -932.6124 0.0000 DIAM 25.4630 25.4598 0.0032 0.0010
