A little code which allow recovery displacements and rotations of a bf alignment.
It's realized here from 9 points, there are some modifications to do if the alignment is constructed from different features...
Have a nice week-end !
Thx to neil.challinor for the help !
A3 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/BF3D,LEAST_SQR,CREATE WEIGHTS=NO,ROTANDTRANS,USE SCALING=NO,0.002,-0.001,-0.008,0.026,-0.021,-0.011 ITERATEANDREPIERCECAD=NO Deviation Threshold=0.01 SHOWALLINPUTS=YES,SHOWALLPARAMS=YES ID=PNT1,Points,,1,YES,YES,YES,YES ID=PNT9,Points,,1,YES,YES,YES,YES ID=PNT2,Points,,1,YES,YES,YES,YES ID=PNT3,Points,,1,YES,YES,YES,YES ID=PNT4,Points,,1,YES,YES,YES,YES ID=PNT5,Points,,1,YES,YES,YES,YES ID=PNT6,Points,,1,YES,YES,YES,YES ID=PNT7,Points,,1,YES,YES,YES,YES ID=PNT8,Points,,1,YES,YES,YES,YES ID= ALIGNMENT/END WORKPLANE/ZPLUS ASSIGN/V10=GETCOMMAND(15,"UP",1) ASSIGN/DEPL_X=GETTEXT(74,1,V10) ASSIGN/DEPL_Y=GETTEXT(74,2,V10) ASSIGN/DEPL_Z=GETTEXT(74,3,V10) ASSIGN/ROT_Z=GETTEXT(149,1,V10) ASSIGN/ROT_X=GETTEXT(149,2,V10) ASSIGN/ROT_Y=GETTEXT(149,3,V10) COMMENT/OPER,YES,FULL SCREEN=NO,AUTO-CONTINUE=NO, DEPL_X ROT_Z ASSIGN/COUNTER=1 DO/ ASSIGN/V13=GETTEXT(3,COUNTER,V10) IF/V13<>"" ASSIGN/COUNTER=COUNTER+1 END_IF/ UNTIL/V13=="" V1 =LOOP/START,ID=YES,NUMBER=COUNTER-1,START=1,SKIP=, OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=0 ASSIGN/V4="PNT"+V1 ASSIGN/DEV_PNT[V1]=SQRT(DOT(V4.XYZ-V4.TXYZ,V4.XYZ-V4.TXYZ)) ASSIGN/V11[V1]=DOT(V4.XYZ-V4.TXYZ,V4.XYZ-V4.TXYZ) LOOP/END ASSIGN/RMS_ERROR=SQRT(SUM(V11)/(COUNTER-1)) COMMENT/OPER,YES,FULL SCREEN=NO,AUTO-CONTINUE=NO, DEV_PNT RMS_ERROR ASSIGN/RZ_LN1=MPOINT(COS(DEG2RAD(ROT_Z)),-SIN(DEG2RAD(ROT_Z)),0) DISPLAYPRECISION/6 ASSIGN/RZ_LN2=MPOINT(SIN(DEG2RAD(ROT_Z)),COS(DEG2RAD(ROT_ Z)),0) ASSIGN/RZ_LN3=MPOINT(0,0,1) ASSIGN/RX_ROW1=MPOINT(1,0,0) ASSIGN/RX_ROW2=MPOINT(0,COS(DEG2RAD(ROT_X)),SIN(DEG2RAD(R OT_X))) ASSIGN/RX_ROW3=MPOINT(0,-SIN(DEG2RAD(ROT_X)),COS(DEG2RAD(ROT_X))) ASSIGN/MTX_ZX_LN1=MPOINT(DOT(RZ_LN1,RX_ROW1),DOT(RZ_LN1,R X_ROW2),DOT(RZ_LN1,RX_ROW3)) ASSIGN/MTX_ZX_LN2=MPOINT(DOT(RZ_LN2,RX_ROW1),DOT(RZ_LN2,R X_ROW2),DOT(RZ_LN2,RX_ROW3)) ASSIGN/MTX_ZX_LN3=MPOINT(DOT(RZ_LN3,RX_ROW1),DOT(RZ_LN3,R X_ROW2),DOT(RZ_LN3,RX_ROW3)) ASSIGN/RY_ROW1=MPOINT(COS(DEG2RAD(ROT_Y)),0,-SIN(DEG2RAD(ROT_Y))) ASSIGN/RY_ROW2=MPOINT(0,1,0) ASSIGN/RY_ROW3=MPOINT(SIN(DEG2RAD(ROT_Y)),0,COS(DEG2RAD(R OT_Y))) ASSIGN/MACHINE2PART_LN1=MPOINT(DOT(MTX_ZX_LN1,RY_ROW1),DO T(MTX_ZX_LN1,RY_ROW2),DOT(MTX_ZX_LN1,RY_ROW3)) ASSIGN/MACHINE2PART_LN2=MPOINT(DOT(MTX_ZX_LN2,RY_ROW1),DO T(MTX_ZX_LN2,RY_ROW2),DOT(MTX_ZX_LN2,RY_ROW3)) ASSIGN/MACHINE2PART_LN3=MPOINT(DOT(MTX_ZX_LN3,RY_ROW1),DO T(MTX_ZX_LN3,RY_ROW2),DOT(MTX_ZX_LN3,RY_ROW3)) COMMENT/OPER,YES,FULL SCREEN=NO,AUTO-CONTINUE=NO, transformation machine to part : MACHINE2PART_LN1 MACHINE2PART_LN2 MACHINE2PART_LN3
