I'm sure there are more reasons than just this to be wary however I've noticed that when using any sort of flow control (Goto statements) you need to have the same tip that you had set before the jump to whatever label you're going to. Otherwise PC DMIS gets very confused and will try to move in weird directions, like full speed into your part for instance. (Don't ask how I found that out
) One would think a move increment of 0,0,6 would just go straight up right? Well not when PC DMIS doesn't know what tip there is.
