With much help, I was finally able to piece together something I have been working on for a while. Would like to share with the forum:
Hopefully this can help someone who works in a high production environment like me.
Be mindful of your F5 settings. ALL NOMINAL FIELDS FOR ALL FEATURES (just nom, not theo), AND ANY MOVE POINTS, MOVE INCREMENTS, WHATEVER MUST HAVE +0 OR *1
of you'll get screwed up by the loop.
Just figure out where the parts will be on your plate to modify the XYZ IF statements as needed, fix the file path for the PDF rpt output to go where you want, make sure all your recall alignments are good, and then go to town.
Happy programming!
STARTUP =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES ALIGNMENT/END RECALL/ALIGNMENT,EXTERNAL,FIXT_ALN_FAKE LOADPROBE/7107_Y_1BY20 TIP/T1A0B0, SHANKIJK=0, 0, 1, ANGLE=0 GROUP_COUNTPROMPT_AND_SERIALNUMBER=GROUP/SHOWALLPARAMS=YES COUNT_PROMPT =COMMENT/INPUT,NO,FULL SCREEN=NO, How many parts are you inspecting? ASSIGN/TOTAL_PARTS=COUNT_PROMPT.INPUT ASSIGN/SER=0 DO/ ASSIGN/SER=SER+1 SER_PROMPT =COMMENT/INPUT,NO,FULL SCREEN=NO, Please enter the Serial Number of the "part at FIXTURE POSITION# "+SER+"." RUN_PROMPT =COMMENT/INPUT,NO,FULL SCREEN=NO, Please enter the Run Number of the "part at FIXTURE POSITION# "+SER+"." ASSIGN/SER_NUM[SER]=SER_PROMPT.INPUT ASSIGN/RUN_NUM[SER]=RUN_PROMPT.INPUT UNTIL/SER==TOTAL_PARTS ENDGROUP/ID=GROUP_COUNTPROMPT_AND_SERIALNUMBER RECALL/ALIGNMENT,EXTERNAL,FIXT_ALN_FAKE ASSIGN/CURR_POS=0 DO/ ASSIGN/CURR_POS=CURR_POS+1 COMMENT/REPT, "Serial Number: "+SER_NUM[CURR_POS] COMMENT/REPT, "Run Number: "+RUN_NUM[CURR_POS] ASSIGN/PROG_NAME=GETPROGRAMINFO ("PARTNAME") ASSIGN/REPORT_NAME="X:\\XXXXXX\\XXXXXXX\\XXXXXX\\PALLET_MACRO_MASTER\\"+PROG_NAME+"__"+SER_NUM[CURR_POS]+"-.PDF" IF/CURR_POS==1 ASSIGN/FIXT_X=0 ASSIGN/FIXT_Y=0 ASSIGN/FIXT_Z=0 END_IF/ IF/CURR_POS==2 ASSIGN/FIXT_X=6 ASSIGN/FIXT_Y=0 ASSIGN/FIXT_Z=0 END_IF/ IF/CURR_POS==3 ASSIGN/FIXT_X=12 ASSIGN/FIXT_Y=0 ASSIGN/FIXT_Z=0 END_IF/ IF/CURR_POS==4 ASSIGN/FIXT_X=0 ASSIGN/FIXT_Y=6 ASSIGN/FIXT_Z=0 END_IF/ IF/CURR_POS==5 ASSIGN/FIXT_X=6 ASSIGN/FIXT_Y=6 ASSIGN/FIXT_Z=0 END_IF/ IF/CURR_POS==6 ASSIGN/FIXT_X=12 ASSIGN/FIXT_Y=6 ASSIGN/FIXT_Z=0 END_IF/ RECALL/ALIGNMENT,EXTERNAL,FIXT_ALN_FAKE PO_PNT =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<0+0,0+0,0+0>,$ MEAS/XYZ,<FIXT_X,FIXT_Y,FIXT_Z>,$ NOM/IJK,<0+0,0+0,0+0>,$ MEAS/IJK,<0+0,0+0,0+0> A1_INIT_ALN =ALIGNMENT/START,RECALL:FIXT_ALN_FAKE,LIST=YES ALIGNMENT/TRANS,XAXIS,PO_PNT ALIGNMENT/TRANS,YAXIS,PO_PNT ALIGNMENT/TRANS,ZAXIS,PO_PNT ALIGNMENT/END $$ NO, ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Actual program goes here Ensure all "F5" settings are correct and prg has +0-s all throughout (in F5 treat thro values as is stored in part coordinates is NOT CHECKED, in F5 update theo values while in loops is NOT CHECKED) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ $$ NO, ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Print command goes here Ensure "always" is selected for header options on insp rpt ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ PRINT/REPORT,EXEC MODE=END,$ TO_FILE=ON,AUTO=1,AUTO OPEN=OFF,$ TO_PRINTER=OFF,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=REPORT_NAME,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$ TO_EXCEL=OFF,$ PREVIOUS_RUNS=KEEP_INSTANCES UNTIL/CURR_POS==TOTAL_PARTS
Happy programming!
