Scripting
  • Scripting
    Alright folks, I'm getting there but not quite. So I have a very small area, and a callout of a position and this area is a Radius. Now I took 4 Polar Radius hits, and Created Assignment Shown below
             ASSIGN/V1=(PNT46.PR+PNT47.PR+PNT1.PR+PNT48.PR)/4
    F1         =GENERIC/CIRCLE,DEPENDENT,CARTESIAN,OUT,$
                NOM/XYZ,<0,0,0>,$
                MEAS/XYZ,<0,0,0>,$
                NOM/IJK,<0,0,1>,$
                MEAS/IJK,<0,0,1>,$
                RADIUS/6,V1
    Now my nominal is fine 0,0,0 center of the part. Can't create a constructed circle. Really crappy numbers. But I know I have have to create something based off of those points to fill in my measured results in that generic circle. need a little help here. Hope This is something easy. JEFMAN , bfire85 , AndersI
    suggestions?
    So you have an area, that is a circle, and you are using 4 polar points, getting the polar radius, and using the assignments to create a generic circle with the correct data?
    As far as I've understood, the best way to use polar points is to measure a FIXED_RAD circle in the area in question, align XYZ to that, then take your 4 points.
    You can then use the center of the circle, polar radius of the points (or V1 in your case) and, if you want, a plane's IJK value or something.
    I don't see why you couldn't evaluate position from this.
    However, I haven't had my coffee today so I may be far off...
    EDIT: Why do you want to use a constructed circle to evaluate the position? Why not the generic?
    • KIRBSTER269
      KIRBSTER269 commented
      my bad I thought you were talking in the drop down in auto feature
    NOM/XYZ,<0,0,0>,$
    MEAS/XYZ,<0,0,0>,$
    NOM/IJK,<0,0,1>,$
    MEAS/IJK,<0,0,1>,$
    RADIUS/6,V1
    suggestions?
    Out of those four hits, maybe construct a Fixed Radius circle using your V1 measurement as your diameter. Then your Fixed Radius X and Y measured location would be the location of F1.
    Something like this:
    PNT1       =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
                THEO/<6,0,0>,<1,0,0>
                ACTL/<6,0,0>,<1,0,0>
                TARG/<6,0,0>,<1,0,0>
                SHOW FEATURE PARAMETERS=NO
                SHOW CONTACT PARAMETERS=NO
    PNT2       =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
                THEO/<6,30,0>,<0.8660254,0.5,0>
                ACTL/<6,30,0>,<0.8660254,0.5,0>
                TARG/<6,30,0>,<0.8660254,0.5,0>
    PNT3       =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
                THEO/<6,60,0>,<0.5,0.8660254,0>
                ACTL/<6,60,0>,<0.5,0.8660254,0>
                TARG/<6,60,0>,<0.5,0.8660254,0>
    PNT4       =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
                THEO/<6,90,0>,<0,1,0>
                ACTL/<6,90,0>,<0,1,0>
                TARG/<6,90,0>,<0,1,0>
                ASSIGN/V1=((PNT1.PR+PNT2.PR+PNT3.PR+PNT4.PR)/4)*2
    CIR1       =FEAT/CIRCLE,CARTESIAN,IN,FIXED_RAD,YES
                THEO/<0+0,0+0,0+0>,<0,0,1>,V1
                ACTL/<0,0,0>,<0,0,1>,12
                CONSTR/CIRCLE,BF,2D,PNT1,PNT2,PNT3,PNT4,,
                OUTLIER_REMOVAL/OFF,3
                FILTER/OFF,UPR=0
    • KIRBSTER269
      Yeah I get that. Was just hoping that it could show up as a Radius because of the callout. Not a Big deal. Just trying to cheat the software.
    • bfire85
      bfire85 commented
      KIRBSTER269, Then cheat the software by creating a generic circle and using the data from CIR1 into the Generic Circle.
    • KIRBSTER269
      Throw me a bone. How so? So I can report it in Xactmeasure
    That's the solution bfire85 and InspectorJester thanks a bunch
      KIRBSTER269 How many degrees are your PR hits from each other?
      • KIRBSTER269
        Maybe a degree or 2. Why?
      • bfire85
        bfire85 commented
        KIRBSTER269 Before you edited your post, you said it didn't work.
      • KIRBSTER269
        Yeah I thought that Inspector was talking about auto circle with the drop down for FIXED_RAD instead of default Least_Square POST #2.1 that wouldn't work
      This be my Surface. bfire85
        The answer to my question was bfire85 result in POST#3. Thank you. You were right to InspectorJester . Thank you
          CIR1 =FEAT/CIRCLE,CARTESIAN,OUT,FIXED_RAD,YES
          FILTER/OFF,UPR=0
          NOM/XYZ,<0+0,0+0,0+0>,$
          MEAS/XYZ,<CIR1.X,CIR1.Y,0+0>,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>,$
          RADIUS/6,CIR1.R
          KIRBSTER269 See above in Red.
          • bfire85
            bfire85 commented
            Glad to help! Great to see you are still hanging around the forums! Good luck in the playoffs!
          • KIRBSTER269
            I walked into kinda of a disaster. Trying to clean up some very crappy programs, I'm on my 3rd broom. Wore the bristles out of other 2.
          • InspectorJester
            InspectorJester commented
            Best of luck KIRBSTER269
          Too late for me
          Have a good afternnon !
          • KIRBSTER269
            I appreciate you just chiming in Jeffery
          Here's something I've developed about a year ago and only use it here and there. Basically tests all values to see if they're in tolerance, for example say 2/3 points are in tolerance but that 1 is out.... averaging the measured results won't flag that one value to be out of tolerance (OOT) instead an average will be reported. Bit of an extreme example, it doesn't really apply with your scenario, but it's possible.
          It's a sub program...
          $$ NO,
                        _____________________________________________________________________________________________
                                       Find the Greatest OOT value or if all in TOL, return average.
                        SUBROUTINE/GREATESTOOTORAVR,
                            VALALL =  : ARRAY INPUT; HOLDS VALUES TO BE PROCESSED,
                            TNOM =  : INPUT; NOMINAL TARGET,
                            TTOL =  : INPUT; NOMINAL'S TOLERANCE,
                            IOUTPUT =  : OUTPUT; GREATEST OOT VALUE OR AVR OF IN TOL VALUES,
                        ASSIGN/IOUTPUT=0
                        ASSIGN/AVRARRAY=FUNCTION((X),SUM(X)/LEN(X))
                        ASSIGN/MYFN=FUNCTION((H,J,G), H<=(J-G) OR H>=(J+G))
                        ASSIGN/FLIPVEC=FUNCTION((X),IF(X<0,X*(-1),X))
                        ASSIGN/VALFROMNOM=FUNCTION((X,Y),X-Y)
                        ASSIGN/H=FLIPVEC(VALFROMNOM(TNOM,VALALL[MAXINDEX(VALALL)]))
                        ASSIGN/C=FLIPVEC(VALFROMNOM(TNOM,VALALL[MININDEX(VALALL)]))
            $$ NO,
                        IF/MYFN(VALALL[MAXINDEX(VALALL)],TNOM,TTOL) OR MYFN(VALALL[MININDEX(VALALL)],TNOM,TTOL)
                          IF/H>C
                            ASSIGN/IOUTPUT=VALALL[MAXINDEX(VALALL)]
                          END_IF/
                          ELSE/
                            ASSIGN/IOUTPUT=VALALL[MININDEX(VALALL)]
                          END_ELSE/
                        END_IF/
                        ELSE/
                          ASSIGN/IOUTPUT=AVRARRAY(VALALL)
                        END_ELSE/
                        ENDSUB/
          PcDmis 2015.1 SP10 CAD++
          Global 7-10-7 DC800S
          • Kp61dude!
            Kp61dude! commented
            It returns the worst OOT out of all inputs or if none are OOT it returns the average of all inputs.
            With a single feature it wouldn't work as you explain. A single feature has a single value (different depending on fit math). You could origin on that circle and send each hit as ARRAY(CIR1.HIT[1].PR, CIR1.HIT[2].PR,CIR1.HIT[3].PR,...) and it would return a value....
          • InspectorJester
            Apologies; I meant to imply the array of hits as you describe. Excellent
          • Kp61dude!
            Kp61dude! commented
            Gotcha InspectorJester test it out and report back.
