UPDATE: I've added the SWITCH variable as it was displaying the dimension result twice.
This is one of those really niche tips that might help out one maybe two people but I thought it was quite cool. When using the CAD graphs for surface profiles it has always bugged me that they stay active resulting in a messy report after several dimensions. I have found a way to capture the CADGRAPH, display it on the report and then turn it off again afterwards before displaying the next feature
This allows you to use CADGRAPH and end up with a clean and crisp report that only shows one profile on each screen capture.
Warning: I use this in a program that has 84 surface profile callouts, while it works perfectly it does dramatically increase saving and loading time.
[COLOR=#EE82EE]ASSIGN/COUNT=0[/COLOR] SCN1START =LABEL/ [COLOR=#EE82EE]IF/COUNT==0 ASSIGN/[/COLOR][B][COLOR=#FF0000]TOGGLE[/COLOR][/B][COLOR=#EE82EE]="BOTH" ASSIGN/[/COLOR][B][COLOR=#008000]SWITCH[/COLOR][/B][COLOR=#EE82EE]="BOTH" END_IF/[/COLOR] [COLOR=#0000FF] IF/COUNT==1 ASSIGN/[/COLOR][B][COLOR=#FF0000]TOGGLE[/COLOR][/B][COLOR=#0000FF]="OFF"[/COLOR] [COLOR=#0000CD]ASSIGN/[/COLOR][B][COLOR=#008000]SWITCH[/COLOR][/B][COLOR=#0000FF]="NONE" END_IF/[/COLOR] SCN1 =FEAT/SET,CARTESIAN THEO/<21.723,21.584,2.446>,<0,0,1> ACTL/<21.677,21.586,2.247>,<0,0,1> CONSTR/SET,BASIC,P8--(1),P9--(1),P10--(1),P11--(1),P12--(1),P13--(1),, FCFPROF1 =SURFACE PROFILE : SCN1 FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES CADGRAPH=[B][SIZE=14px][COLOR=#FF0000]TOGGLE[/COLOR][/SIZE][/B],REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,ARROWDENSITY=100,OUTPUT=[SIZE=14px][B][COLOR=#008000]SWITCH[/COLOR][/B][/SIZE],UNITS=MM COMPOSITE=NO, CUSTOMIZED DRF=NO STANDARDTYPE=ASME_Y14_5 PRIMARY DIMENSION/PROFILE OF SURFACE,1,UNEQUAL TOLERANCE ZONE,0.7,A1,<dat>,<dat> NOTE/FCFPROF1 FEATURES/SCN1,, COMMENT/REPT, SCNVIEW1 =VIEWSET/ RECALL/VIEWSET,SCNVIEW1 [COLOR=#EE82EE]IF/COUNT==0 DISPLAY/METAFILE, "", TO FIT, GOOD END_IF/[/COLOR] [COLOR=#0000FF]IF/COUNT==0 ASSIGN/COUNT=COUNT+1 GOTO/SCN1START END_IF/[/COLOR]
