CSV to XLSX
  • CSV to XLSX
    Hey
    I'm looking for something on the forum for ripping to an exel file.
    and this works well but I can not get it as an xlsx file.
    I have a exel file where only nominal sizes want to append on a exel location
    in the yellow boxes.
    I'm not sure I understand what you're asking.
    Your title says "CSV to XLSX" - that's as easy as "import CSV in Excel, save as XLSX". But the rest of your post doesn't seem to mean that.
    If you mean what I think you mean - you want to import only the measured values into an existing worksheet - the easiest way [I know of] is to write an Excel macro that fetches all measured values from PC-DMIS and puts them in the right place. No PC-DMIS involved (except for having the values you want to fetch).
      yes I want to get dimensions in xlsx but I can not. but only in csv
      and it has to be put into an existing exel file and a special place it is for a final control report
        PC-DMIS can export to xlsx if Excel is available on the PC-DMIS computer, but not to pre-determined positions in an existing sheet, so not really helpful anyway.
        So, you have to export to csv from PC-DMIS, open your xlsx master in Excel, open the csv in Excel, transfer the numbers from the csv sheet to the correct positions in the master sheet. If you record a macro while doing all those transfers, you can later repeat the same thing by just running the macro.
        Or, you could write a PC-DMIS Basic script that controls Excel, opens the master, reads the labels in the master one by one and locates the corresponding dimension in PC-DMIS, outputting the value to the current row in the Excel sheet. I have never done anything like that, so I don't know how difficult it could be...
          but I do have another idea, if I open the values ​​in another sheet of exl I can then send them to the good sheet and postision I do not know if you can help me how I get files only in xlsx
            Which version of PC-DMIS? At least in 2016 (I don't have anything older) and later, you have it under File -> Printing -> Report Window Setup..., the Excel tab (see picture).
            But I don't understand why CSV would be a problem? The same Excel that opens your xlsx can open a csv in another worksheet??
              I do not use that I just want to have specific measurements on exel.
              so I do it with i / o comando and that does not work with xlsx
                Then you have to do it as outlined above - have a master xlsx, open that in Excel, open your csv in Excel, run an Excel macro that moves the values from the csv worksheet to the xlsx worksheet.
                or
                Skip the I/O in your pp:s, in your xlsx master you write an Excel macro that explicitly grabs the correct values from PC-DMIS and puts them in the right place. I have an Excel workbook doing something like that, but as it is a product we (Hexagon Metrology Nordic AB, Sweden) sell, I can't give out too much coding details... This one needs the operator to click the Read button in Excel after each part is run.
                • Kp61dude!
                  Kp61dude! commented
                  Nice and Neat! As always you can expect quality stuff from AndersI
                Here is link that might be useful in your endeavors.
                https://www.pcdmisforum.com/forum/pc...-to-a-csv-file
