Running Collection of Useful Tips
  • Running Collection of Useful Tips
    This is a dual purpose topic, proposed to contain a collection of Useful Tips & Tricks some of us use on a daily basis; both to share with the community and to have a copy on the cloud when I forget!
    First and foremost, the "0+0" rule.
    For whatever reason, PC-DMIS loves to change nominals!
    In order to fix this completely, any number that you'd like to not change needs to be set to an equation*
    *I'm sure there are numbers that probably won't change very much...
    I personally don't like to write out 0+0 every time I have the need for a 0.
    I can't remember who told this to me (it was 100% from this forum, someone will probably own up to it) but I like to assign a variable instead.
    ASSIGN/ZERO=ABS(0)
    ASSIGN/ONE=ABS(1)
    Now, whenever I need to have a 0 or 1, I just type zero or one.
    This brings up a lot of points.
    First and foremost, it is extremely important to be able to understand what you're programming. If you start making variables willy-nilly, and don't have a way to differentiate V1 from V187 without going through the variables and finding out what you had assigned them 2 years ago, you're gonna have a bad time.
    However, if you set a variable called NOTCH_1_L_180, you know that that variable should be the nominal location of Notch 1 at 180° (part-dependant obviously).
    Let's say you have two parts that are almost identical. You take the time to create a variable for every single aspect of every feature you're going to measure (it doesn't take as much time as it sounds).
    Now all you have to do is File>Save as the new part number, change some variables and shell the program. Everythings all set up and ready to go, the new variables are initialized and the features reset once it's shelled.
    Personally I prefer to program using this method. Creating a variable for everything makes the program less likely to change, but makes it easier to change at the same time.
    I personally do a lot of work with parts that come from a blank, say 15 different parts with the same notches at different locations, diameters, and depths.
    I can program 1 part in a day or 6, and the other 14 the next day (exaggerated).
    I'll always know what the variables mean, because I understand my own naming convention.
    Mine, personally (as listed above) is the type of feature, the order of the feature (I go from datum to non datum, where applicable), what aspect of the feature (L for lcoation, D for Depth, R for Radius, etc) and the degree of rotation the feature is at (I work with round parts, if you haven't heard).
    The variables themselves are nothing special, just the absolute value of whatever the blueprint says (I rarely get lucky with CAD models).
    So instead of having to remember ever single number and dimension on the print, I just have to know that the Y-Axis is this variable, X is that, etc.
    Makes it easier for me to program, anyhow.
    Hopefully I'll add more to this eventually
    I also thought this was useful:
    When using the Auto Line Feature, Surface Vector is the Workplane, the Edge Vector is the vector of the actual hits, and the Line Vector is the actual vector of the line
    • InspectorJester
      InspectorJester commented
      Per vpt.se, explaining how workplanes affect lines
      Originally posted by vpt.se View Post
      If you are in a workplane perpendicular to your line (workplanes normal/vector is parallel with the line direction) you will get a zero length line result.
    Try to avoid crashing!
    • Schrocknroll
      Schrocknroll commented
      That's what I've been doing wrong all these years. Thanks!
    I'd really like to include something about alignments. I go for the Level-Rotate-Origin alignment process for our cylindrical parts; Leveling to the OD (cylinder), Rotating to a notch (plane or line, depending), and origining to the OD and a point.
    It would be cool to explain more of the process of why that's the way to go; I understand it simply locks down all 6 (DOF's? D'sOF? DOF?) degrees of freedom, and it lets me run my parts. However, I see a lot of times where there's not enough attention paid to the alignments.
    I can't imagine any good data being retrieved from a program with a bad alignment. Data can be retrieved, and the numbers could very well be in tolerance, but I couldn't trust a program that's not aligned properly. It's like trusting your CMM measures fine when it's out of calibration; sure, it could be fine, but do I need to go into detail as to why it could not?
    At any rate; if someone could help me explain alignments better, I'm sure we could all benefit.
      Next; instructions.
      I see pretty good instructions on this forum, both from individuals answering questions and from those asking.
      However, I see more often than not a question that is explained incoherently or inadequately, or is missing that *one* sliver of information that either solves the issue, or makes it unsolveable.
      The point is, I personally, and I'm sure many others on the forum, would appreciate if you could put some time into your questions. Plan them out, go through them to make sure that if an individual has no idea who you are, or anything about the nuance of metrology you happen to come from, but they know a bit about PC-DMIS, they can still answer your question to the T.
      It helps me out a lot when I see a post and I can actually understand the question!
      I understand this is not always easy; being a world-wide software, there are plenty of opportunities for communication problems! However, if the question is posed as something along the lines of:
      Help! I'm trying to make a line and it won't work!
      Then nobody will be able to help, just based on that information.
      Instead, we are going to have to go through the painstaking process of asking you the simple questions.
      Such as "well how are you doing it"?
      It would be nice if, when I went on the forum to try to answer a question or 6, I got greatly worded questions. They're all great questions, don't get me wrong, but too many times I've seen 3 pages of people asking 6-word questions to the OP, and then 1 post that has either a quick answer that can't be understood unless you go through every page of posts, comments and all, or 5 different answers and the OP just replies "That worked, thanks", if they reply at all!
      This is sort of defeating the purpose of the forum; you might as well google it (which brings up a whole different thread entirely...)
      So, in short, if you want a quick and concise answer, you have to provide a full explanation of what you're working with.
      What did you do, post the ***king code, what have you tried, etc, not just one question that has to force us to ask questions to understand what's up!
      I just wanna help you guys; I would really appreciate if you'd make it easy for me!
      Sheesh, this sounds way more negative than I had originally intended..
      • Kp61dude!
        Kp61dude! commented
        Not negative. Someone has to say it, thank you for saying it. I like the Stackoverflow manages their forum. People vote on answers that work for them. When browsing thru their forum and I find a post related to my issue I quickly jump to the #1 voted respond after reading the OP question. It's awesome, wish we copied them.
      Actually it doesn't *love* it, many users almost never experience it, but if you give PC-DMIS the preconditions for changing nominals, it has to obey, however unwillingly. The fact that we don't realize we've given PC-DMIS those contradicting facts/datas doesn't mean anything to PC-DMIS, it's just a computer program without feelings.
      Among these preconditions are
      - not locking all 6DOF of the final alignment
      - long chains of alignments depending on each other instead of referring back to START every time we lock all 6 DOF
      - variables in alignment commands
      - other ways? Fill in...
      • InspectorJester
        Originally posted by AndersI View Post
        ...it's just a computer program without feelings.
        The program doesn't love it; it just hates me! :P
      • vpt.se
        vpt.se commented
        It also depends on your PC-DMIS version. From 2012 (I think) there was a registry setting that was changed to TRUE in order to prevent PC-DMIS from changing nominals (which did the trick). So, in the newer versions it should not happen - unless you have a condition listed by AndersI above.
      • Kp61dude!
        Kp61dude! commented
        So very true. I used to experience this as a wee ol lad but now I don't experience nominals changing anywhere.
      AndersI The last two certainly apply to me!
      I try to create a course alignment, a progressive alignment, and then a final locked-in alignment.
      When I say progressive alignment, I create a cylinder by measuring 4 or 5 circles, aligning to each circle/creating a cylinder & aligning to that (when more than 1 circle has been measured)
      It is these circles that cause me the nominals-changing issues I've got!
      (Which would make sense consider what you just told me! Lol)
      So, what would be a good workaround to this? I could rework the alignments to recall startup for that section, but I'd like to keep the variables in place if I can.
      +1!
        Tip of the day:
        If you find that you need to do something in PC-DMIS, but there's not an explicit control for it, hack it!
        For example, if you want to save a report to a new location every time (e.g. serialized naming convention), instead of trying to mess around with the Print command, which is the control that actually outputs the report, you could use File/IO commands to simply copy the default file to a new location with a serialized name, and delete the default!
          Here's a tip: let the forum subcategory, titled "Tips and Tricks" collect the useful "Tips and Tricks".
          Post new messages even for the little things. It makes it easier for people to find!
          Kill this post.
          To be fair? Review the entire list of topics here. Hardly Tip's n' Tricks... but more so for those who ignore the 'use as directed' label. It's Off-Topic up the wazoo.
          This whole thread farm became a dumpster fire......... please call the Hexagon Halon Squad
          • InspectorJester
            Some cleanup wouldn't hurt...
