Program gets slower
  • Program gets slower
    I'm using 2020 r1 Sp6, In which i made a program using Vision probe, but the demon starts going slower. It takes longer time to pull up the dimension windows & some times it hangs. Is anyone facing the same issue ?
    MAN_ROT_LN =FEAT//LINE/DEFAULT,CARTESIAN,UNBOUNDED
    THEO/<-3.0009,-1.3096,-0.0805>,<1,0,0>,<0,-1,0>,<0,0,1>,0.298
    ACTL/<-0.8081,-4.9575,-14.3517>,<0.9999924,-0.0039007,0>,<-0.0039007,-0.9999924,0>,<0,0,1>,0.2964
    TARG/<-3.0009,-1.3096,-0.0805>,<1,0,0>,<0,-1,0>,<0,0,1>
    SHOW FEATURE PARAMETERS=NO
    SHOW_VISION_PARAMETERS=NO
    ALIGNMENT/ROTATE,XPLUS,TO,MAN_ROT_LN,ABOUT,ZPLUS
    ALIGNMENT/TRANS,YAXIS,MAN_ROT_LN
    ALIGNMENT/TRANS_OFFSET,YAXIS,1.299
    ALIGNMENT/END
    MAN_XY_SLTR=FEAT//ROUND SLOT/DEFAULT,CARTESIAN,IN
    THEO/<0,0.0106,0.4003>,<0,0,1>,<0.9999588,0.009078,0>,0 .2743,0.3403
    ACTL/<1.7695,0.0064,-13.8814>,<0,0,1>,<0.9999943,0.0033726,0>,0.2721,0. 3406
    TARG/<0,0.0106,0.4003>,<0,0,1>,<0.9999588,0.009078,0>
    ALIGNMENT/TRANS,XAXIS,MAN_XY_SLTR
    ALIGNMENT/TRANS,YAXIS,MAN_XY_SLTR
    ALIGNMENT/END
    MAN_Z_PT =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<-0.5,0,0>,<0,0,1>
    ACTL/<-0.6778,-0.0392,-14.3191>,<0,0,1>
    TARG/<-0.5,0,0>,<0,0,1>
    SNAP=NO
    A3 =ALIGNMENT/START,RECALL:A2,LIST=YES
    ALIGNMENT/TRANS,ZAXIS,MAN_Z_PT
    ALIGNMENT/TRANS_OFFSET,ZAXIS,-0.5
    ALIGNMENT/END
    MODE/DCC
    TEMP_ROT_LN=FEAT//LINE/DEFAULT,CARTESIAN,UNBOUNDED
    THEO/<-2.5,-1.3096,0.4375>,<1,0,0>,<0,-1,0>,<0,0,1>,0.298
    ACTL/<-2.4991,-1.3055,0.4375>,<1,0.000178,0>,<0.000178,-1,0>,<0,0,1>,0.2964
    TARG/<-2.5,-1.3096,0.4375>,<1,0,0>,<0,-1,0>,<0,0,1>
    A4 =ALIGNMENT/START,RECALL:A3,LIST=YES
    ALIGNMENT/ROTATE,XPLUS,TO,TEMP_ROT_LN,ABOUT,ZPLUS
    ALIGNMENT/TRANS,YAXIS,TEMP_ROT_LN
    ALIGNMENT/END
    TEMP_XY_SLTR=FEAT//ROUND SLOT/DEFAULT,CARTESIAN,IN
    THEO/<0,0.0106,0.934>,<0,0,1>,<-1,0,0>,0.273,0.342
    ACTL/<0,0.006,0.934>,<0,0,1>,<-0.9999959,-0.00287,0>,0.2722,0.3411
    TARG/<0,0.0106,0.934>,<0,0,1>,<-1,0,0>
    A5 =ALIGNMENT/START,RECALL:A4,LIST=YES
    ALIGNMENT/TRANS,XAXIS,TEMP_XY_SLTR
    ALIGNMENT/TRANS,YAXIS,TEMP_XY_SLTR
    ALIGNMENT/END
    TEMP_Z_PNT =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<-0.5,0,0.5>,<0,0,1>
    ACTL/<-0.5,0,0.4911>,<0,0,1>
    TARG/<-0.5,0,0.5>,<0,0,1>
    SNAP=NO
    A6 =ALIGNMENT/START,RECALL:A5,LIST=YES
    ALIGNMENT/TRANS,ZAXIS,TEMP_Z_PNT
    ALIGNMENT/END
    ZP_1 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<-2,-1,0.5>,<0,0,1>
    ACTL/<-2,-1,0.5117>,<0,0,1>
    TARG/<-2,-1,0.5>,<0,0,1>
    SNAP=NO
    ZP_2 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<-1,-0.5,0.5>,<0,0,1>
    ACTL/<-1,-0.5,0.5012>,<0,0,1>
    TARG/<-1,-0.5,0.5>,<0,0,1>
    SNAP=NO
    ZP_3 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<1,0.5,0.5>,<0,0,1>
    ACTL/<1,0.5,0.5008>,<0,0,1>
    TARG/<1,0.5,0.5>,<0,0,1>
    SNAP=NO
    ZP_4 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<2,1,0.5>,<0,0,1>
    ACTL/<2,1,0.5103>,<0,0,1>
    TARG/<2,1,0.5>,<0,0,1>
    SNAP=NO
    DAT_A =FEAT/PLANE,CARTESIAN,TRIANGLE,NO
    THEO/<0,0,0.5>,<0.0469096,-0.0938191,0.9944835>
    ACTL/<0,0,0.506>,<0.4472135,-0.8944272,-0.0000221>
    CONSTR/PLANE,BF,ZP_1,ZP_2,ZP_3,ZP_4,,
    OUTLIER_REMOVAL/OFF,3
    FILTER/OFF,WAVELENGTH=0
    TEMP_ZP_1 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<0,0.175,0.949>,<0,0,1>
    ACTL/<0,0.175,0.9451>,<0,0,1>
    TARG/<0,0.175,0.949>,<0,0,1>
    SNAP=NO
    A7 =ALIGNMENT/START,RECALL:A6,LIST=YES
    ALIGNMENT/TRANS,ZAXIS,TEMP_ZP_1
    ALIGNMENT/END
    DP_L1 =FEAT//LINE/DEFAULT,CARTESIAN,UNBOUNDED
    THEO/<-0.0258,0.1365,-0.015>,<1,0,0>,<0,-1,0>,<0,0,1>,0.0494
    ACTL/<-0.0251,0.136,-0.015>,<0.9999963,0.0027306,0>,<0.0027306,-0.9999963,0>,<0,0,1>,0.0477
    TARG/<-0.0258,0.1365,-0.015>,<1,0,0>,<0,-1,0>,<0,0,1>
    DP_L2 =FEAT//LINE/DEFAULT,CARTESIAN,UNBOUNDED
    THEO/<-0.0277,-0.1365,-0.015>,<1,0,0>,<0,-1,0>,<0,0,1>,0.0497
    ACTL/<-0.0267,-0.1364,-0.015>,<0.9999871,0.0050712,0>,<0.0050712,-0.9999871,0>,<0,0,1>,0.048
    TARG/<-0.0277,-0.1365,-0.015>,<1,0,0>,<0,-1,0>,<0,0,1>
    DATUM_B =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<-0.0268,0,-0.015>,<1,0,0>
    ACTL/<-0.0259,-0.0002,-0.015>,<0.9999924,0.0039009,0>
    CONSTR/LINE,MID,DP_L1,DP_L2
    SLT_CR1 =FEAT//CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<-0.0345,0,-0.015>,<0,0,1>,0.273,107.9847,250.5313
    ACTL/<-0.0344,-0.0001,-0.015>,<0,0,1>,0.2721,108.1873,250.3699
    TARG/<-0.0345,0,-0.015>,<0,0,1>
    ANGLE VEC=<1,0,0>
    SLT_CR2 =FEAT//CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0.0345,0,-0.015>,<0,0,1>,0.273,289.4426,71.5836
    ACTL/<0.0343,0.0001,-0.015>,<0,0,1>,0.272,289.8037,71.2274
    TARG/<0.0345,0,-0.015>,<0,0,1>
    ANGLE VEC=<1,0,0>
    RECALL/ALIGNMENT,INTERNAL,A6
    TEMP_ZP_2 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    ACTL/<-2,-1,0.5119>,<0,0,1>
    SNAP=NO
    A8 =ALIGNMENT/START,RECALL:A6,LIST=YES
    ALIGNMENT/TRANS,ZAXIS,TEMP_ZP_2
    ALIGNMENT/END
    PRF1 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<-2.3927,-0.4345,0>,<0,0,1>
    ACTL/<-2.3932,-0.4353,0>,<0,0,1>
    TARG/<-2.3927,-0.4345,0>,<0,0,1>
    PRF2 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<-0.1601,0.354,-0.015>,<0,0,1>
    ACTL/<-0.1613,0.3555,-0.015>,<0,0,1>
    TARG/<-0.1601,0.354,-0.015>,<0,0,1>
    PRF3 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<2.2942,1.299,-0.015>,<0,0,1>
    ACTL/<2.2927,1.3052,-0.015>,<0,0,1>
    TARG/<2.2942,1.299,-0.015>,<0,0,1>
    TEMP_ZP_3 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<3,0,0.409>,<0,0,1>
    ACTL/<3,0,0.436>,<0,0,1>
    TARG/<3,0,0.409>,<0,0,1>
    SNAP=NO
    A9 =ALIGNMENT/START,RECALL:A8,LIST=YES
    ALIGNMENT/TRANS,ZAXIS,TEMP_ZP_3
    ALIGNMENT/END
    DP_1 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<3.55,1.299,-0.015>,<0,-1,0>,<0,0,1>
    ACTL/<3.55,1.3047,-0.015>,<0,-1,0>,<0,0,1>
    TARG/<3.55,1.299,-0.015>,<0,-1,0>,<0,0,1>
    CP_1 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<4.232,0.6525,-0.015>,<-1,0,0>,<0,0,1>
    ACTL/<4.2314,0.6525,-0.015>,<-1,0,0>,<0,0,1>
    TARG/<4.232,0.6525,-0.015>,<-1,0,0>,<0,0,1>
    CP_2 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<4.232,-0.6525,-0.015>,<-1,0,0>,<0,0,1>
    ACTL/<4.2309,-0.6525,-0.015>,<-1,0,0>,<0,0,1>
    TARG/<4.232,-0.6525,-0.015>,<-1,0,0>,<0,0,1>
    DP_2 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<3.55,-1.299,-0.015>,<0,1,0>,<0,0,1>
    ACTL/<3.55,-1.2963,-0.015>,<0,1,0>,<0,0,1>
    TARG/<3.55,-1.299,-0.015>,<0,1,0>,<0,0,1>
    TEMP_ZP_4 =FEAT//SURFACE POINT/DEFAULT,CARTESIAN
    THEO/<-3,0,0>,<0,0,1>
    ACTL/<-3,0,-0.0339>,<0,0,1>
    TARG/<-3,0,0>,<0,0,1>
    SNAP=NO
    A10 =ALIGNMENT/START,RECALL:A9,LIST=YES
    ALIGNMENT/TRANS,ZAXIS,TEMP_ZP_4
    ALIGNMENT/END
    PRF4 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<-2.5552,0.3351,-0.015>,<0,0,1>
    ACTL/<-2.5516,0.335,-0.015>,<0,0,1>
    TARG/<-2.5552,0.3351,-0.015>,<0,0,1>
    PRF5 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<-3.815,0.2798,-0.015>,<0,0,1>
    ACTL/<-3.8151,0.2783,-0.015>,<0,0,1>
    TARG/<-3.815,0.2798,-0.015>,<0,0,1>
    RECALL/ALIGNMENT,INTERNAL,A8
    PRF6 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<-2.275,-1.299,-0.015>,<0,0,1>
    ACTL/<-2.2748,-1.3048,-0.015>,<0,0,1>
    TARG/<-2.275,-1.299,-0.015>,<0,0,1>
    PRF7 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<0.1601,-0.354,-0.015>,<0,0,1>
    ACTL/<0.1629,-0.3545,-0.015>,<0,0,1>
    TARG/<0.1601,-0.354,-0.015>,<0,0,1>
    PRF8 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<2.4076,0.4173,0>,<0,0,1>
    ACTL/<2.408,0.4177,0>,<0,0,1>
    TARG/<2.4076,0.4173,0>,<0,0,1>
    RECALL/ALIGNMENT,INTERNAL,A9
    PRF9 =FEAT//PROFILE 2D/DEFAULT,OPEN,CARTESIAN
    THEO/<3.5969,-0.2604,-0.015>,<0,0,1>
    ACTL/<3.5951,-0.2605,-0.015>,<0,0,1>
    TARG/<3.5969,-0.2604,-0.015>,<0,0,1>
    RECALL/ALIGNMENT,INTERNAL,A10
    DP_3 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<-3.55,1.299,-0.015>,<0,-1,0>,<0,0,1>
    ACTL/<-3.55,1.2963,-0.015>,<0,-1,0>,<0,0,1>
    TARG/<-3.55,1.299,-0.015>,<0,-1,0>,<0,0,1>
    CP_3 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<-4.232,0.6525,-0.015>,<1,0,0>,<0,0,1>
    ACTL/<-4.2311,0.6525,-0.015>,<1,0,0>,<0,0,1>
    TARG/<-4.232,0.6525,-0.015>,<1,0,0>,<0,0,1>
    CP_4 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<-4.232,-0.6525,-0.015>,<1,0,0>,<0,0,1>
    ACTL/<-4.2318,-0.6525,-0.015>,<1,0,0>,<0,0,1>
    TARG/<-4.232,-0.6525,-0.015>,<1,0,0>,<0,0,1>
    DP_4 =FEAT//EDGE POINT/DEFAULT,CARTESIAN
    THEO/<-3.55,-1.299,-0.015>,<0,1,0>,<0,0,1>
    ACTL/<-3.55,-1.3047,-0.015>,<0,1,0>,<0,0,1>
    TARG/<-3.55,-1.299,-0.015>,<0,1,0>,<0,0,1>
    DL_1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<-3.55,1.299,-0.015>,<1,0,0>
    ACTL/<-3.55,1.2963,0.002>,<0.9999993,0.0011867,0>
    CONSTR/LINE,BF,2D,DP_3,DP_1,,
    DL_2 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<-3.55,-1.299,-0.015>,<1,0,0>
    ACTL/<-3.55,-1.3047,0.002>,<0.9999993,0.0011826,0>
    CONSTR/LINE,BF,2D,DP_4,DP_2,,
    CL_1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<4.232,-0.6525,-0.015>,<0,1,0>
    ACTL/<4.2309,-0.6525,0.0189>,<0.0003431,0.9999999,0>
    CONSTR/LINE,BF,2D,CP_2,CP_1,,
    CL_2 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<-4.232,-0.6525,-0.015>,<0,1,0>
    ACTL/<-4.2318,-0.6525,-0.015>,<0.0005352,0.9999999,0>
    CONSTR/LINE,BF,2D,CP_4,CP_3,,
    DATUM_D =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<-3.55,0,-0.015>,<1,0,0>
    ACTL/<-3.55,-0.0042,0.002>,<0.9999993,0.0011846,0>
    CONSTR/LINE,MID,DL_1,DL_2
    DATUM_C =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
    THEO/<0,-0.6525,-0.015>,<0,1,0>
    ACTL/<-0.0004,-0.6525,0.002>,<0.0004392,0.9999999,0>
    CONSTR/LINE,MID,CL_2,CL_1
    DATUM_A =GENERIC/PLANE,DEPENDENT,CARTESIAN,$
    NOM/XYZ,<0+0,0+0,0+0>,$
    MEAS/XYZ,<0+0,0+0,0+0>,$
    NOM/IJK,<0*0,0*0,1*1>,$
    MEAS/IJK,<0*0,0*0,1*1>
    DATDEF/FEATURE=DATUM_A,A
    DISPLAYPRECISION/4
    FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,OUTTOL,
    SCN1 =FEAT/SET,CARTESIAN
    THEO/<0.0232,0.0086,0.6881>,<0,0,1>
    ACTL/<0.023,0.0086,0.7057>,<0,0,1>
    CONSTR/SET,BASIC,PRF1,PRF2,PRF3,PRF4,PRF5,PRF6,PRF7,PRF8, PRF9,,
    A12 =ALIGNMENT/START,RECALL:A6,LIST=YES
    ALIGNMENT/LEVEL,ZPLUS,DATUM_A
    ALIGNMENT/ROTATE,YPLUS,TO,DATUM_C,ABOUT,ZPLUS
    ALIGNMENT/TRANS,ZAXIS,DATUM_A
    ALIGNMENT/TRANS,XAXIS,DATUM_C
    ALIGNMENT/TRANS,YAXIS,DATUM_B
    ALIGNMENT/END
    DIM_1 =LINE PROFILE : SCN1
    FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES
    CADGRAPH=POSITION,REPORTGRAPH=OFF,TEXT=OFF,MULT=10 .00,ARROWDENSITY=100,OUTPUT=BOTH,UNITS=IN
    CUSTOMIZED DRF=NO
    STANDARDTYPE=ASME_Y14_5
    PRIMARY DIMENSION/PROFILE OF LINE,0.01,<UZ>,<UTol>,A,<dat>,<dat>
    NOTE/DIM_1
    FEATURES/SCN1,,
    ANALYSISVIEW/DIM_1,,
      Have you restarted the software recently? I know I have been having memory leaks in the software in which I need to restart it once a day.
      • Thiyagu_Raj
        Thiyagu_Raj commented
        yes, So many times. but still no use.
      When in doubt, close it out! Yeah definitely try a restart. and maybe try copying your features to a fresh program if you are still getting issues
      • Thiyagu_Raj
        I already informed to regional hex Tech guy & the response i got was"PC-Dmis, is failing to handle large number of points"
      Thiyagu_Raj How many points are in your program?
      Maybe your computer processor is too slow for a large program that is calculating a lot of data?
        To bank off what LaserJay said, does your computer meet the minimum requirements?
        - PC-DMIS 2020 R1 operates under 64-bit Windows 10, Windows 8.1, Windows 8, and Windows 7.
        - Microsoft .NET Framework 4.6.1 for Windows.
        - 4 GB of RAM or higher
        - 1 GB of video RAM
        - 2 GHZ or higher quad core processor
        - Video Card: GPU Memory 2 GB DDR3, Memory Bandwidth 29.0 GB/s, CUDA Cores 384, Open GL 3.0
        - Make sure you have enough space on your hard drive
          Due to busy schedule can't come online, Here is my system config.
          The program has around 15k points, the program has 2D Auto profile and the point density is changed to low.
            Do you have the status window open/visible in PC-DMIS? if yes, try closing it to see if it makes any difference.
            PC-DMIS CAD++ 2o19 R1 SP10
            • Thiyagu_Raj
              No, it doesn't make any difference.
