Optiv 443, using the CWS white light, to create a scan using recalled surface points. Can I recall surface points into a scan?
Scan
by UKCHAMPOptiv 443 Dual Z. Using the white light, can I generate surface points and recall them into a scan?
08-08-2019, 06:10 AM -
Hi,
I am trying to create a scan on a CAD surface. It doens let me select the boundary points. No Idea why.
11-18-2019, 11:42 AM -
by mitkosI would like to scan a surface following an irregular, or made up of geometric shapes curve (red) that is on that surface all the way around (sample on...I would like the option to scan the surface following an irregular, or made up of geometric shapes curve (red) that is on that surface all the way around (sample on the picture)
02-07-2017, 11:01 AM -
by NMC_CMMHey all,
I've got a tapered oblong pocket that I'm trying to inspect for the milling dept. Usually I just take surface points off the...-
10-08-2010, 04:23 PM -
by yeakeydIs there any other way to dimension and report out data from a WLS scan other than turning the scan into points and dimensioning from there??
06-21-2013, 10:22 AM -
