I'm trying to modify the DMIS output in DMIS export by selecting the Flexible DMIS option which can be customized by the functions in the VBScript file. There is 6 existing VBScript files which I assume can be cloned and modified to create a certain flavor of DMIS output. When I use anyone of the 6 existing VBScript files the DMIS output contains Macro calls i.e. CALL/M(PCD_AUTO_VECTOR_POINT_605),(IML1),4.3261,29.1137 ,6.5414,$ but does not create the Macros in the DMIS file. Are these Macros internal system Macros inside PcDmis?
Thanks.
Thanks.
