Set up axis
  • Set up axis
    Anyone can support me to setup axis like the picture
    no use code please
    I don't see a picture attached.
    Time for the Trolls to leave.
      I update again , please support
        Looks like you already did it.
        So you probably:
        Leveled to a plane Z+
        You made an XY origin (C1) circle
        Rotated about a generic line (X axis) you made @ XYZ 0,0,0 and IJK 1,0,0 and length of your choice C1 --------- generic line -------------> OR:
        a line you construct by point from C1 to a point you constructed from an OFFSET point (C2 offset Yminus by value of A)
        But sequence to make your alignment (ALN) is:
        • Level to Z
        • Rotate to X plus about Z plus using Rotated line created above.
        • X and Y origin to C1
        • Z origin to your Z plane
        (I am probably very confused about your question)
        good luck!
          Offset line between CIR1 - CIR2 with the value of [a] - see sealevel above for complete alignment.
          PC-DMIS CAD++ 2o23.1
            Thank both of you but i still can't do it. Can you support by make a video or picture of each step
              i wanted to know the same. Looking forward to the video
                Construct line.
                Select "offset".
                Select the two circles.
                Click "Offset".
                Enter the value that the line should be offset from the two circles. Here the offset for c1 should be zero and for c2 the value of a.
                Click OK.
                Click Create.
                Doublecheck that the line were created as you expected. If not, try switching the offset value to negative.
                • Hoodlum
                  Rescale Axis
                  by Hoodlum
                  How do I rescale the part axis?
                  I need to have the positive "X" Axis for the machine going in the opposite direction.
                  12-09-2009, 10:48 AM
                • dopalicious
                  Z axis counter balance
                  by dopalicious
                  Could someone supply me with a picture of the regulator for the Z axis counter balance for a B&S Excel 9 15 9? Is it located on the X axis?
                  02-13-2018, 09:55 AM
                • keego
                  H Axis
                  by keego
                  Sounds like a noob question but here goes:
                  What the heck is the H axis? Sometimes when reporting diameters, along with the diameter comes...
                  05-19-2010, 03:55 PM
                • jswope
                  Reporting
                  by jswope
                  We are using pc-dmis 4.2. When I add a dimension like distance or angle, the relationship can be set to feature, X axis, Y axis, or Z axis....
                  03-03-2008, 10:05 AM
                • CMM Guru
                  Left Handed Axis Systems
                  by CMM Guru
                  Having an issue reading the axis system from the native model. Its a left handed axis from Catia. When imported in PC-DMIS is forcing it to become right...
                  06-10-2013, 10:22 AM
