I used an auto-line to measure a feature and want to construct a line from the two highest points. How do I go about doing this? If I'm not mistaken, PC-DMIS creates the line with an average of all the points it takes with the auto-line.
Two Highest Points on a Line
Try this:
Code:ASSIGN/V1=MAXINDICES(LINE2.HIT[1..LINE2.NUMHITS].X) ASSIGN/V2=LINE2.HIT[V1[1]].XYZ ASSIGN/V3=LINE2.HIT[V1[2]].XYZ F1 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<V2.X,V2.Y,V2.Z>,$ MEAS/XYZ,<V2.X,V2.Y,V2.Z>,$ NOM/IJK,<1,0,0>,$ MEAS/IJK,<1,0,0> F2 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<V3.X,V3.Y,V3.Z>,$ MEAS/XYZ,<V3.X,V3.Y,V3.Z>,$ NOM/IJK,<1,0,0>,$ MEAS/IJK,<1,0,0> LINE4 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO THEO/<0.03,5.734,-0.596>,<0,1,0> ACTL/<0.03,5.734,-0.596>,<-0.0093185,0.9999566,0> CONSTR/LINE,BF,2D,F1,F2,, OUTLIER_REMOVAL/OFF,3 FILTER/OFF,WAVELENGTH=0
First of all, note that the two highest points of the line - in the current alignment - doesn't necessarily simulate a real (physical) tangent line, if that's what you actually need. In that case, if you have PC-DMIS 2019 R1 (or later), you should use the new Line construction method "Secondary Datum" to achieve this.
To find the two highest points relative to the *line*, you need to be aligned to the line.
Note that the code from bfire85 assumes that X is your 'up', the direction you look for the highest point in. Change the .X, in the first ASSIGN, to .Y or .Z depending on your reality.Last edited by AndersI; 05-02-2019, 09:39 AM.AndersI
- Likes 1
can pc-dmis measure and create a line and simultaniously create the points that made the line?
open dmis had the option.-
03-12-2009, 03:11 PM -
by dtmtimIt sounds like such a simple thing. Create a line between 2 intersection points. I have done this hunderds of times using vector points but for some...
12-07-2006, 09:09 AM -
by DuroseHi everyone, I am new to this board and PD-DMIS. I need some help please. I have been using a PC-DMIS for several months. In the past I have routinely...
01-31-2007, 10:06 AM -
by DmisDavePicture a 2” X 3” block laying flat on the table. The 3” is the “X” and the 2” is the “Y”. (Z won’t matter for this.)
My 2”...-
05-14-2009, 11:52 AM -
