vision 300
  • vision 300
    so the probe is calibrated but the y axis (on the readout on the bottom of the screen oand the cntl+w one ) is not registering that it is moving but everything else is moving fine
    it is a vision 300 running pcdmis pro 4.2
    Maybe the motor is shot? Is there any grinding noise? Is this happening with manual or DCC movements? or Both?
      the readout doesnt do anything it is manual only but makes no noise... you think calibration would help? it says it is calibrated so doesn't make much sense
        Is the Y axis locked on the jog box?
          there is no job box
          • bfire85
            bfire85 commented
            You don't have a controller?? Controller / Joystick = Jog Box
          • sealevel
            sealevel commented
            there is no job box
            now THIS ^^^^^^^^^^^^^^ could be a problem!
          Did you already try shutting down the whole system and rebooting? What happens when you try to measure a circle? Does it report the correct diameter?
          bfire85 I can't lock out axes with my Vision jogbox
          • bfire85
            bfire85 commented
            Yeah, I can't either. Disregard my post above.
