How to get data Min/Max diameter of circle
  • How to get data Min/Max diameter of circle
    Hi. I have problems, I need out put data min and max diameter (or radius) and graphic after measure circle.
    Please give me some advises.
    Optiv Classic 443
    PCDMIS 2017 R1
    There are a lot of threads about this, and each time, the first question is :
    What do you call min and max diameters ?
    Min circ and max inscribed, or on a LS circle, max distance between hits and center and min dist ?
    For the second case, just dimension legacy location with only "form" selected, then insert in the report an analysis view with min/max selected.
      Make an auto-circle with as many hits as you want
      Click in your edit window. Hit F10. Click to dimension tab. Click on all of the stuff you want showing in your dimensional output (in your case, click on min/max and click off what you don't want).
      After the dimensional output in your edit window, go to Insert/Report Command/Analysis and setup a view that you'll add to your report.
        Turning on MAX/MIN will output the max and min diameters, but it won't evaluate them.
        DIM DIM_1= LOCATION OF CIRCLE CIR1  UNITS=IN ,$
        GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
        AX    NOMINAL       +TOL       -TOL       MEAS        DEV     OUTTOL        MAX        MIN
        D       2.0000     0.0050     0.0050     2.0008     0.0008     0.0000     2.0100     2.0000 -----#---
        END OF DIMENSION DIM_1
        If you want to evaluate them, you need to recompute them and report them separately.
        CIR2       =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                    THEO/<1,0,0>,<0,0,1>,6
                    ACTL/<1,0,0>,<0,0,1>,6
                    TARG/<1,0,0>,<0,0,1>
                    START ANG=0,END ANG=360
                    ANGLE VEC=<0.7071068,0,0.7071068>
                    DIRECTION=CCW
                    SHOW FEATURE PARAMETERS=NO
                    SHOW CONTACT PARAMETERS=YES
                      NUMHITS=36,DEPTH=0,PITCH=0
                      SAMPLE METHOD=SAMPLE_HITS
                      SAMPLE HITS=0,SPACER=0.25
                      AVOIDANCE MOVE=NO,DISTANCE=0.5
                    SHOW HITS=NO
        SCN1       =FEAT/SET,CARTESIAN
                    CONSTR/SET,BASIC,CIR2.HIT[1..CIR2.NUMHITS],,
        CIR3       =FEAT/CIRCLE,CARTESIAN,IN,MAX_INSC,NO
                    CONSTR/CIRCLE,BF,2D,SCN1,,
                    OUTLIER_REMOVAL/OFF,3
                    FILTER/OFF,UPR=0
        CIR4       =FEAT/CIRCLE,CARTESIAN,IN,MIN_CIRCSC,NO
                    FILTER/OFF,UPR=0
        DIM DIM_2= LOCATION OF CIRCLE CIR3  UNITS=IN ,$
        D       2.0000     0.0050     0.0050     2.0000     0.0000     0.0000 ----#----
        END OF DIMENSION DIM_2
        DIM DIM_3= LOCATION OF CIRCLE CIR4  UNITS=IN ,$
        D       2.0000     0.0050     0.0050     2.0100     0.0100     0.0050 -------->
        END OF DIMENSION DIM_3
          Dimension Circularity on the circle and use the Analysis Window to get a graphical display with MAX and MIN labeled.
            Since version 2017R1, pc-dmis correctly reports 2 sizes for diameters using the SIZE dimension. Exactly what these 2 results are depends on ASME / ISO setting. (and ISO has a lot of different options)
            You need to take a lot of points for this to work properly. I highly recommend using this size dimension.
            • JEFMAN
              JEFMAN commented
              Maybe an even number of hits is needed to make it work correctly...
            • AndersI
              AndersI commented
              That's not necessary. I's doing some clever interpolation to check diametrically opposing 'points'. But the larger the number of points, the closer to 'reality'...
            And if you have an older version, this post - https://www.pcdmisforum.com/forum/pc...ure#post392957 - may help...
            Loading...
