DCC Search for Auto-Line Larger than FOV Question
  • DCC Search for Auto-Line Larger than FOV Question
    Is PC-DMIS Capable of searching in an area larger than the FOV for a line?
    If not, has anyone automated an iterative search for a feature in an area larger than the FOV? (Without stopping the routine with '... not detected' errors)
    Thank you
    You should be able to key-in how long you want the line and in which direction. PC-DMIS will continue to measure in that zone from start to stop.
      Ok, let me explain a little further:
      I want to measure an edge oriented on the X-axis. The length of the line is smaller than the FOV_X. But I do not know where this line is on the Y-Axis. I would like PC-Dmis to search along the Y-Axis until it finds the edge that is oriented on the X-Axis. (Fully automated - Without prompts or Errors)
      something along the lines of:
      Auto-Line (X = 0, y = -5)
      if error then
      Auto-Line (X = 0, y = -3)
      if error then
      Auto-Line (X = 0, y = 0)
      end if
      end if
      end if
      Please let me know if you have any idea if this is possible!
        Michael,
        I have not had a lot of experience with them but they are useful.
        It sounds like you could manipulate a few of the follow features to work in your favor.
        -Possibly some sort of scan depending on the situation(Only if TTP is included)
        -You can perform an edge point with sample hits(Only if TTP is included)
        -Using a combination of Logic, Label and Looping commands may just get you want you want
        Just some ideas
        Good Luck!
        Anthony Fotion
        Quality/Reliability Engineer Technician
        Fujifilm Dimatix Inc.
        E-mail: [email protected]
          Thank you
          Check out the help literature for the ONERROR command. It can be done.
          Ex Hex
          • Ken8282
            Creating a line
            by Ken8282
            Good Morning
            I have a part where the origin is created from two lines that intersect. However the lines are .100 from the edge of the part...
            06-05-2017, 12:26 PM
          • jonny
            Edge Scan
            by jonny
            I am trying to perform an edge scan, but the machine keeps crashing when I do so. I believe the main reason is my inexperience with a CMM, so I hope...
            03-22-2006, 12:30 PM
          • Liambo734
            Finding an edge
            by Liambo734
            I have a callout which is the height of a raw edge. One side of the edge is a plane, the other side is a free surface. The edge is the intersection between...
            12-19-2013, 12:59 PM
          • TheBradish
            Construct Features from Edge Point Hits
            by TheBradish
            I'm using an Auto Edge Point to measure a sharp corner dimension, but I also want to measure the angle of one of the related surfaces. I have tried constructing...
            06-09-2015, 10:55 AM
          • racerx00
            edge point isssue
            by racerx00
            I am just loaded 4.2 mr2 and got everything up and running i thought. when i use edge point and tag in the middle of a line, it moves to the closest...
            01-12-2009, 02:38 PM
