Vision coordinates to touch probe
  • Vision coordinates to touch probe
    I heard it was possible to capture the center coordinates of a feature and feed them to the touch probe.
    Example:
    I'm looking down on a cube, the camera captured the edges and determined the center.
    Now I want my touch probe to locate the cube using the coordinates captured by the camera to go and measure the z height.
    I heard it was possible but was never shown how.
    Thanks
    You can capture an approximate Z height with the top or ring light. Create an alignment with the Z-axis to that point, then the X-Y location based on the edges. Go grab your probe and the probe should easily locate the Z based on the alignment.
    When the call is bigger than you...www.lyricsandlife.online
      Yes, just what bfire said.
      As long as your probe offset is all calibrated, take the points you want around your cube with I am assuming backlight. Before you move onto your probe switch to your toplight and take a "Surface Point" on the top of your cube with your vision and make that your Z origin in your alignment. The probe will know exactly where to go.
      Anthony Fotion
      Quality/Reliability Engineer Technician
      Fujifilm Dimatix Inc.
      E-mail: [email protected]
