Is there a way to utilize a Pro-e model to difine edges in PSDMIS Vision on round parts?
Cylindricle Pro e models and PCDMIS Vision
What version? 4.0 dosen't work that way at least not from my expereince. PCDmis can not find an edge as it runs down the legth of a cylinder; only surface.
The auto feature tools in vision seam very limited.
Please show me an example
Keep in mind I'm refering to use of vision with 3D models and not 2D and on multi sensor units, where tactile and vision can be used.
Hi
The reason I delayed in posting my reply to your original question was because I wanted to test to make sure before I answered. I took a 3d ProE model that we have from our set of test parts, imported it, and programmed an arc and circle on it. (it was Version V41 I tested but I don't believe anything has changed in that area since V4.0). I think I had to swap to surface mode in order to do this, but our surface mode will now do single click detection on a number of basic features.
It's the same cad programming tools for Vision and Contact auto features, so I'm not sure what limitations you are referring to? Please be more specific.
Perhaps you can mail me an example part you're struggling with so I can try to program it up?
by rangerboat72Has anyone tried upgrading a Nikon Veritas VM-250 vision system to PC-DMIS vision?
If so what problems have you encountered?
Channel: PC-DMIS Vision
06-13-2006, 09:44 AM -
by nkayWAIPC-DMIS Vision V4.0 currently supports running on the following machine types :-
TESA VISIO 1
TESA VISIO 300 Manual
TESA VISIO...-
03-01-2006, 05:46 PM -
Does pcdmis vision have a few different levels like all other pcdmis or not? Basically does it come automatically with the CAD option or does it need...
06-27-2013, 10:27 AM -
by BKulpaI've been working with PC-Dmis CMM for about 15 years.
I also have experience with an OGP vision system (which I hate the software) for about the...-
05-06-2016, 07:53 PM -
by KyleBSorry for the rant here. But I've had a ticket open on vision support since the 21st of Feb. https://support.hexagonmi.com/s/detail/5003z00001wHJT6A...
03-08-2019, 02:43 PM -
