OGP Vision system
  • OGP Vision system
    Has anyone tried upgrading an OGP Avantzip vision system to PC-DMIS vision?
    If so what problems have you encountered?
    We're looking at a measuemind / smartfit upgrade but the price seems to be almost as much as changing to PC-DMIS.
    To date, we've only done Smartscopes, but may be able to support Avant. I'd need more information from you to know.
    1) Machine model and data of mfg (should be on serial number tag)
    2) Machine options (rotary, TP, laser, optics, etc)
    3) Machine config files file found in the config directory.
    · hardware.cfg
    · EEPROM.DAT
    · NLCORFAC.CFG
    4) Pictures of machine if possible
      Here's the info on the system
      nkayWAI,
      Model: Avantzip 400 ZIP
      S/N: AZ4001115
      Date: Dec. 1999
      Drawing# SScope-0292
      I've attached the config files and a photo.
      There is no eeprom.dat file.
      The system only has the optics and a "Smart Ring" light system.
      Please let me know what you think ASAP, as we're looking at an OGP computer/software upgrade.
        aahh, the avant uses the same hardware as the smartscope...
        Where are you connecting in at on the OGP's? at the parallel cable or are bypassing the DSP board?
          cmmguy, I've responded via PM as this information is not in the public domain.
