Accuracy? Does A Faro Arm Need Controlled Temp?
  • Accuracy? Does A Faro Arm Need Controlled Temp?
    Hi Everyone,
    Does a Faro Arm with a Scanning head on it need to be in a controlled environment to hold tolerances within .0005?
    I think you need a miracle to hold 0.005" with a faro arm.
    Seriously, I don't think a faro is even close to that capable.
    • VinniUSMC
      VinniUSMC commented
      Drama queen.
    We have two Faro arms. They do have temp comp built into the arm to help with being out on the floor. They will never hold a .0005 tolerance. They can hold a steady .003 all day long. Good luck!
      Okay, we had a guy come down from Faro. He guarantees they have a Faro Arm with temp comp arms, 4 foot diameter, that will hold accuracy within .0002. What do you all think about this. They just came out with these
      • VinniUSMC
        VinniUSMC commented
        The answer really lies between Matt and your Faro guy. .0002" point repeatability measuring a 1" sphere? Maybe. .0002 volumetric, laughably BS.
      If by controlled you mean steady temperature, then yes. All measuring instruments need a stable temperature. Temp comp WILL NOT "fix" a non-stable temerature.
      Arms arent capable enough to measure to those accuracies. Your average Bridge CMM wont hold those accuracies.
      Everyone knows the saying about "how to tell if a salesman is lying", well there is a more realistic one. Ask them to tell you exactly how many years they have worked in the shop using the type of equipment they are selling, if the answer is more that 3 years, then there is a 95% likely chance they are telling the truth. Otherwise, they have no idea what literature means in the real world and you will have to find the truth yourself.
        Hello,
        Having dealt with Faro, this will not hold those tolerances...
        It will hold .002" - .004", depending on the operator.
        A.Gore
        sigpicA.Gore
          Okay great. Thanks for the help [email protected]
            Hello,
            i have a 08 faro arm platinum 6ft arm 6 axis ..
            how much could i sell for ? Was thinking around 8k.. is that accurate?
            Thanks!
              Originally posted by Pitpenguinsfan View Post
              Hello,
              Thanks!
              Measure some gauge blocks and some rings, and you will have an idea of the real accuracy...
              If you have a perpendicularity cylinder or a standard square, measure them to see the 3D accuracy (gauge blocks and rings gives only the accuracy on lengthes / size, 3 d features add angles accuracy !).
                How can I come up with an accurate price then based on that?just looking for top value for the piece .
                Thanks!
                • InspectorJester
                  InspectorJester commented
                  One way to get an idea is to see what others are selling them for (e.g. google "faro arm platinum for sale" and check out some prices).
                  Upcharge as you see fit
                Wow, this is the best Necro-thread I've seen in a while .0002" on a portable arm, that's rich.
                Systems Integrator
                • VinniUSMC
                  VinniUSMC commented
                  On technology that is at least 10 years old, no less.
                  I didn't notice that it was necro'd to solicit, lol, oops.
                I bid 8 gazillion bitcoins.
