I recently got a new computer for my Romer Arm. I loaded Win RDS and PCDMIS 3.7 onto my new laptop following all the instructions, but when I open PCDMIS I get a error saying "interfac.dll will not load". Does anyone have any suggestions?
PCDMIS won't open on Romer!
Originally posted by jtrot55 View PostI recently got a new computer for my Romer Arm. I loaded Win RDS and PCDMIS 3.7 onto my new laptop following all the instructions, but when I open PCDMIS I get a error saying "interfac.dll will not load". Does anyone have any suggestions?
What it is telling you is that your port lock is not set for the interfac.dll file that Pcdmis used for the install. Copy the interfac.dll file from the old PC to the new one.sigpic
Next, if you are using WinRDS 4.3 or older, there is one step you must perform manually to get it working with PC-DMIS. Go to your the Control Panel in Windows and double click on System (or right click on My Computer and select Properties). Click on the Advanced tab and click the button Environment Variables. Under System Variables, highlight the variable 'Path' and click on the Edit button. Keep everything that is already in the path, but add a semi colon ';' to the end (if there isn't one already) and copy and paste the following after the semi-colon:
C:\Program Files\CIMCORE\WinRDS
Click OK to accept all changes in every window that is currently open. That's it!
For the record, I highly recommend PC-DMIS versions 4.1 - 4.2 MR1 when using ROMER arms.
Stu
When you use romer arm, you mast change the interfac.dll
Go to: program files/wai
there you find interfac.dll -make a backup and delete it.
after you must find file "romer.dll" copy and paste this file and the copy rename to interfac.dll.
you know that when you use romosoft, first you must install PC-DMIS after the romosoft with product cd.
regards
Adam Orvos
by MarkusGood morning.
We have recently installed Pc-Dmis 2015. The application starts up fine and the Romer seems to connect to our computer fine,...-
Channel: PC-DMIS Portable
07-27-2015, 09:57 AM -
by FDAVIS1I recently had to completely restore my laptop that is used for the Romer Arm to the factory condition but after installing PCDMIS 4.2 MR1 I am getting...
11-23-2011, 12:32 PM -
I have new install PCDMIS, but can't connect to romer, the error occurs " Invalid DLL : GDSDLL.DLL" Do you know how to solve these?
01-09-2007, 01:54 AM -
by mconklinI have pcdmis installed on the new computer but where can I get the cimcore arm utlities to be able to run on new computer
04-26-2012, 05:11 PM -
by jleondHi,
I just got a used 3000i Romer arm, it came without laptop and software. Can you recommend a good laprop for PCDMIS Portable (CAD++),...-
08-03-2009, 04:21 PM -
