Axis of a cylinder as Datum A - Datum B is, or is not, parallel to the Datum A plane
  • Axis of a cylinder as Datum A - Datum B is, or is not, parallel to the Datum A plane
    I thought I'd revive this discussion. I've searched the forums and read the other threads on using the axis of a cylinder as Datum A. I don't think they answered the question I have here.
    With reference to the print below, if I use the "Level Z+ to the cylinder" guideline, then in relation to the print, Z+ is pointing to the right (presuming vector directions). Then, it seems that the Datum B plane is PARALLEL to the [piece of paper] Datum A "plane", and therefore can't constrain rotation of the Z+ plane.
    Now, the engineer insists that I'm wrong because the datum callout is to the AXIS of the cylinder, which is indeed perpendicular to Datum B.
    My question is, how do I achieve this in PC-DMIS? If I construct a line in the Z+ workplane from A to C, and then use that to constrain the rotation, am I not effectively replacing Datum B with Datum C? Then Datum B simply becomes the place to put the Z origin.
    How would you gurus approach this?
    Another issue - the Datum C hole asks for A(M) - if Datum A is merely the axis line of the cylinder, can we even say it's a feature "of size"?
    Also, would you probe Datum C as a cylinder, or as a circle with sample hits?
    Datum "A" (shaft) controls 4 DOF, 2 rotational and 2 axial
    Datum "B" (surface?) controls 1 axial DOF
    Datum "C" (hole) controls 1 rotational DOF
    6 DOF, all done.
    I see no other way those datums can control all 6 DOF.
    CAN/MAY/MUST rule applies.
    "A" can control 2 rotational and 2 axial DOF, and it MAY since they are not previously controlled, so it MUST control those 4 DOF
    "B" can control 2 rotational and 1 axial DOF, but it MAY NOT control the rotational since they are already controlled, it MAY control 1 axial DOF, so it MUST control 1 axial DOF
    "C" can control 2 rotational and 2 axisl DOF, but it MAY NOT control 1 of those rotational and 2 of those axial since they are already controlled, it may control 1 rotational DOF so it MUST control 1 rotational DOF.
    This is for a callout of A-B-C. It all shuffles around if the callout isn't A-B-C
    Of course, this is all based on proper use of GD&T.
      Okay, so it seems I was wrong, which isn't the first time. So does either or both of these look acceptable?
        both look wrong, you can't rotate the same axis as you already leveled to.
        Level to the cylinder, rotate to a line from the "A" to "C", I would do it by making pierce points of BOTH in the "B" plane.
        Level to cyl "A"
        Rotate to constructed line from A/B point and C/B point
        Set 2 axis to "A" and one to "B"
        • wish2bflying
          wish2bflying commented
          Oh duhh. I was really tired and distracted last week. I know not to do that, so I'm not sure what I was thinking.
          Having said that, if we're essentially ignoring Datum B and constraining the rotation using a line from A to C, aren't we proving that Datum B is invalid?
        • Matthew D. Hoedeman
          Matthew D. Hoedeman commented
          nope, it just ends up being simply a single axis origin feature.
          Dan says the same thing as I said, just different words.
        Your print gives fully defined instructions.
        New alignment that RECALLS STARTUP....
        Level to -A-
        Rotate -A- to -C- in the vector direction the features make ABOUT whatever you leveled to
        -A- is X&Y origin. -B- is Z origin.
        Regarding -C-...you can measure it as either a circle or cylinder. Looks like you'd be good with a circle in this case & sure why not? Use sample hits, it can't hurt...
        I use circles if I have a lot of tolerances and don't need to use that geometry for any fancy GD&T like concentricity or runout.
        Be careful! A2 is rotating twice. A2 is also an alignment that is fully defined with 6 DOF yet is recalling an alignment that isn't STARTUP (unnecessary). Finally, A2 's XYZ origins are out of order. When I train people, I always instruct them to LEVEL, ROTATE, XYZ IN THAT ORDER EVERY TIME so you're alignments are always "good"/you don't forget anything.
          "B" is a plane perp to "A", how can it origin 2 axis?
        • DAN_M
          DAN_M commented
          Sorry I can't type today, is fixed now
        wish2bflying
        In response to #4.1.
        -B- isn't ignored. And it is valid! It just geometrically can't be used to constrain rotation because it is along the same vector as the feature you're leveling through.
        -A- has a Z vector, so you need to rotate to something that has an X or Y vector. Rotating from cir-cir gives you the Y vector.
        Level Z, rotate to X or Y about the Z, XYZ origin. Bingbangboom.
        CAN/MAY/MUST
        -A- CAN and MAY/therefore MUST be leveled to the Z.
        -B- has a Z vector so it CAN NOT be rotated about the Z for this alignment.
        I realize I sound repetitive but I am trying to break this down for your benefit. Hopefully its helping!
        • RSNICKER
          Datum A
          by RSNICKER
          I have received some drawings where Datum A is on the diameter and Datum B is on a surface. I normally level to Datum A and align to Datum B and I'm not...
          09-25-2008, 01:54 PM
        • Netter
          Alignment for perp
          by Netter
          I have a part that is round with a hole in the center and a flat surface on top. Think of it as a 2" thick washer. The perp is from the face to the...
          08-31-2007, 01:45 PM
        • drago8813
          Datum swap and xact measure
          by drago8813
          I am measuring a part where datum feature A is a cylinder and have a perpendicularity to a plane. I aligned using the cylinder as primary and the plane...
          04-05-2017, 11:16 AM
        • Radar
          Stuck on an alignemnt (take two)
          by Radar
          I tried to use X-act measure to see if it would help me understand how to create the alignment needed to report feature callout. It seemed to raise more...
          03-21-2018, 10:10 PM
        • dtmtim
          Alignment Help
          by dtmtim
          Good morning, the datums defined on the customer print are a bit confusing and may not be defined correctly (big surprise).
          Datum A =...
          02-01-2007, 09:00 AM
