FORMAT/TEXT change is messing up display of GeoTol dimensions ABOVE the change
  • FORMAT/TEXT change is messing up display of GeoTol dimensions ABOVE the change
    I did find another thread about PDF reports and GeoTol dimensions that mentioned this but didn't go into specifics.
    I started seeing that if I change the dimension format from this:
    FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS,SD;NOM,TOL,MEAS,M AXMIN,DEV,OUTTOL,
    to this:
    FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS,SD;NOM,MEAS,DEV,, ,,
    it messes up the display of GeoTol dimensions above the change. I've tried going in and "forcing" a change above each dimension line, but it doesn't affect it. The only thing that seems to work is to add OUTTOL to the line I want to NOT have OUTTOL on!
    This is now an intermittent issue. In my experimenting, it magically worked one time, which I got a copy of, and then I tried being a good scientist and tried re-creating the issue, and it has never come back to "good".
    This is what I want:
    This is what I keep getting:
    This is what I've had to settle for:
    Same issue here.
    That was probably my thread: https://www.pcdmisforum.com/forum/pc...-report-issues
      This might be resolved. In the latest program, I made sure to have ALL the options in the lower section selected:
      Then when I go to the BASIC dimension section it seems to work properly:
        I tried that with no luck.
          Another piece to the puzzle. I don't usually auto-generate reports. I used a program written by someone else, which auto-generated a report, and then I did my own "Save/Print" to generate the PDF, and the one that I did manually had the problems, but the one that was auto-generated at the end of running the measurement routine did NOT have the problems.
            I've been told this is a confirmed bug report that now has a ticket in to have it fixed in a future update. Can anyone confirm this?
            This is now proving to be an intermittent issue. It is really cramping my style here, and I'm finding that in some instances I have to generate reports with all the dimension fields showing.
              I was told it's a confirmed bug as well. Now to wait for the fix...
