Has anyone had any success scanning clear glass? We just recently got the Romer arm and our training was interrupted because of COVID
Scanning Glass
When I used to scan car windscreens we used to measure the thickness of a Matt Sticky tape and then stick it on the screen in bands,
By offsetting the CAD by the thickness of the tape it enabled us to scan quite easily.
Not sure how tight the tolerances are your working to but that method worked fine for Automotive glass tolerances.
Made in Essex
PC-DMIS CAD++ 2018 R1
Dea Mistral
Dea Global
B&S Micro Xcel
Faro Edge LL Scanner
Polyworks
try misting it with developer from a spray can, have done this to scan chrome plated/mirror finishes with good success.
if you apply a very light mist it will add less than .001" thickness to the surface and reduce noise to nothing.
It is also pretty fast to clean up, wipes off completely with a dry rag.
this is what specifically I used https://www.magnaflux.com/Products/SKD-S2.htm
- Likes 1
The new RS6 scanner (compatible with the 8 series arms) is now capable of scanning glass without the usage of developer spray. It has a ''high gain'' parameter in RDS, and when that parameter is activated, it can scan glass, mirror finished machined parts, shiny black etc. Below you've got an example of a car window scan with the RS6 (5 minute scan)
UK Applications Engineer
PC-DMIS Portable and Pointcloud Scanning
- Likes 2
by PacMan23hey guys I am working on Scanning a round Tank End with a Romer Arm Laser and want to know what type of powder I could apply to help with the reflectiveness...
09-23-2017, 10:01 AM -
We just received out new 7.10.7 CMM. It came with the Hexagon scanning head. We have never used a scanning head before and we will be going down for training...
05-17-2018, 08:00 AM -
by louisdHas anyone else experienced issues conducting a simple 'probe reset' after a movement interruption, while using this probe head? I already submitted...
02-19-2019, 06:15 PM -
by CookeaMy employer is finally considering sending some of us for level 2 PCDmis training (Yay!). I was looking at the descriptions for 201 and 202 and the latter...
01-11-2019, 09:51 AM -
by mazo2000Hello,
In our mould shop we have start to use PC DMIS for electrode measurements and for core/cavity measurements.
From...-
09-15-2014, 02:55 PM -
