I have a CAD model with a circle, nominally 7.8" in diameter. I can only measure about 90 degrees of the circle, so it's more like a radius. Using 6mm Probe. Clicked on the CAD to do an Autocircle of this 7.8" diameter O.D. radius, but for whatever reason it selected I.D. of the same diameter. Correct workplane, everything that I can see. I didn't notice that the autocircle defaulted to ID so I measured the O.D. and continued on. Now the diameter is off, as expected due to probe comp. But it is off 12mm. Can someone explain that to me? Shouldn't the error be 6mm??? Please help.
Confused about Probe Compensation on a CAD model and AutoCircle
by caryweaverDoes anyone know what would cause a program to measure a radius off exactly the diameter of the stylus? The program was created offline, and did not...
12-04-2014, 01:19 PM -
by leafsfan224Hey guys need some help here.
I am trying to get radius when i take points from a CAD by creating a circle. But when i take the hits,...-
Channel: PC-DMIS Portable
01-23-2014, 02:20 PM -
by JLHUTTHelp, I have a part that is about 3.5" long (round) with an I.D of 1.5" in diameter. On one end of the I.D. there is a radius of 1.5",...
01-03-2008, 08:14 AM -
by jakhillJust learned that the 2nd shift guy measured a part I shipped this morning with a 2mm ruby probe, when the program had a 1mm sheet metal probe. Is there...
12-15-2015, 03:29 PM -
Anyone else running into sizing issues on the circle auto feature?
I have a pin that's designed at 21.5 mm. I verify that it's designed at...-
07-17-2017, 07:54 AM -
