Best fit on profile of a line (technical question)
  • Best fit on profile of a line (technical question)
    Hello,
    Does anyone have a useful link to learn more about the least squares best fit. I'm looking forward to do manual calculations for a line profile data set.
    Thanks,
    Could you describe a little more.
    The line is on the flat section, or is it an edge ?
    Do you "cut" the COP construct a line ?
    I would say profile in front of standards should use minmax vector.
      The deviations can be calculated by different ways :
      - least square (alone) just uses distances between measured values and theo values :
      ASSIGN/V1=SQRT(DOT(SCN1.HIT[1..SCN1.NUMHITS].XYZ-SCN1.HIT[1..SCN1.NUMHITS].TXYZ,SCN1.HIT[1..SCN1.NUMHITS].XYZ-SCN1.HIT[1..SCN1.NUMHITS].TXYZ))
      and then minimizes the sum of the square of deviations.
      - least square vector uses the definition of the deviation, which is the projection of the deviation along the theo vector :
      ASSIGN/V2=DOT(SCN1.HIT[1..SCN1.NUMHITS].XYZ-SCN1.HIT[1..SCN1.NUMHITS].TXYZ,SCN1.HIT[1..SCN1.NUMHITS].TIJK)
      - minmax vector uses also the definition of deviations, but the algorithm search to minimize the difference between the max deviation and the min deviation.
      ​​​​​​​You can try using the excel sheet in the #6 here, I'm not sure it works fine in english...
      https://www.pcdmisforum.com/forum/pc...ares-vs-vector
        That's different values that I find (different than yours !):
        Minimax 0.4933
        max 0.5157
        min 0.0224
        LS vector 0.6377
        max 0.2516
        min -0.3270
        LS only 1.7577278
        max 0.4933
        min -0.3738
          Yep, values are approximately the same (can change after the 4 decimal place)
          Init is used to start the calculation with 0 on each displacement.
          LS only is the minimization of distances with least squares, LS vector is distances along the vector and minmax also.
            I think it's because of the deviations along z.
            On theo values, there's a variation between 5 and 33 mm, so the vectors shouldn't be <0,0,1>.
            Projecting along the vector or calculating the distance "point to point" (meas to theo) give very different results because the distance are not measured along the same direction.
              I would use minmax vector...
              LS vector is intersting if there are some outliers hits...
              I can't answer to your question without seeing the part, the method...
              I just would say that you can give the result that you want if you add to the result the algo used...
                I think it should be the same,exept if my prog is wrong !
                • JEFMAN
                  JEFMAN commented
                  I made it on my own, just applying what I know...
                  I know that a french teacher wrote something about it, I don't know if he did it in english (Bernard Anselmetti).
                  You can try a google search with "using excel solver in gd&t" ?
                https://docs.hexagonmi.com/pcdmis/20...nt_Methods.htm
