Color Map P.I.S.T. score
  • Color Map P.I.S.T. score
    can you get a P.I.S.T. score from a color map/point cloud scan?
    Hi Matthew D. Hoedeman ,
    P.I.S.T score as I understood is Percentage of Inspection Points Satisfying Tolerance. We do have option in the colormap dialog. Click the check box 'show distribution percentages' in the color scale editor dialog and you should be able to see how much of the percentage lies in what color of the tolerance band.
    If this is not what you are looking for., I would like to request for more details.
    Regards,
    Krishna Chaitanya Velisetty
    Metrology Software Applications Specialist,
    Hexagon Manufacturing Intelligence.
    • CodeWarrior
      PC-DMIS Application Events via C#
      by CodeWarrior
      So through the process of improving my app for automating pc-dmis I have undertaken the task of converting parts of my app from vbscripts to all C# code....
      02-24-2020, 06:47 PM
    • Paul Sarrach
      Your SMA not at work:
      by Paul Sarrach
      After I put the call into B&S and called me back the next day, they worked on it for 2 days. And this is thier reply by email no less:
      10-11-2007, 10:37 AM
    • Rploughe
      Operator Login
      by Rploughe
      here is a basic script for a simple operator login.
      Sub[SIZE=2][COLOR=#000000] Main[/COLOR]
      [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Begin[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#000000] [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dialog[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#000000] DIALOG_1 50,10, 300, 125, oOPERATORINPUT[/COLOR]
      GroupBox[/]
      01-21-2014, 01:52 PM
    • Rploughe
      Expression information pulling with VB Script
      by Rploughe
      Hello all,
      Some little things I was curious about. Can't really figure our the syntax of.
      [/SIZE][SIZE=2][COLOR=#007f00][SIZE=2][COLOR=#007f00]'PCDMIS[/][/][/][/]
      06-20-2014, 01:39 PM
    • alphew
      Leitz styli's which are not defined in PC-DMIS
      by alphew
      As I mentioned in my previous thread , my company has just bought a new Leitz 24.16.12 which is runnning with PC-DMIS 4.3. While I am trying to set up...
      11-09-2009, 04:25 AM
