Good afternoon.
Is it true that positions that are called out on a detail drawing do not pertain to final drawing? For instance, we will be running a part that calls for true position callouts on the detail level. On the final part, bosses get welded into the holes. Does the true position callout no longer apply on the final weldment since it is not called out on the final weldment print? So when the part gets welded and the bosses flex one way or the other, we will still have a good part? Is this a quality standard or simply based on customer preference?
Thank you.
Thank you.
