I just switched to windows 10 and I am running pc-dmis 2017R2, now after software was installed it want see the probes. does anyone know why??? thanks for your help in advance.
RDS and PC-DMIS want see probes
No Schrocknroll
Probes on Romer arms are Automatically detected..Each probe has a module that stores the calibration from Hexagon..The problem is that when you re install you must re do the connection method RDS is using to communicate to pcdmis...So you must open RDS and go to the connection page and from there determine how it was connected before either wireless or a wired connection.Michael A Wildschutz Sr
I Walk on The WildSide
"To Each is Own"
by mconklinI am looking to buy some new probes and was wondering if anybody had some good sites to look at
11-29-2010, 01:14 PM -
by DeWain HodgeI've been using an FCR25 on our new ONE since November. Starting yesterday it started to not always leaving the probes in their ports when changing probes...
05-28-2009, 08:37 AM -
by metalfabpmrunning infinite 2.0 portable pc-dimis cad 4.3 need more probes. looking to purchase 60 & 90 deg x 150mm point & ruby tip.
what are the...-
09-23-2010, 11:00 PM -
by metalfabpmHas any one purchased romer factory hook probes? If you have what are the pros & cons. I have been able to measure points accuratly for now, but the...
Channel: PC-DMIS Portable
04-16-2012, 11:57 AM -
by metalfabpmusing infinite arms 1.0 & 2.0 pc-dmis cad 4.3 looking to purchase 60 deg & 90 deg x 150 mm carbide point & ruby tip probes anyone using these....
09-24-2010, 11:15 AM -
