I just have a GD&T question and was hoping you may be able to help. The drawing of a shaft (attached) calls out "1.50 Max Runout." The 1.5 appears to be the measurement from the end of the shaft (1.5 inches). So what is Max Runout? I know what runout is, but is there a standard for Max Runout? Thanks.
GD&T Question
I am thinking that this is trying to control the break out end of the tool path, you have a 1.00 min flat , then a Rad for teeth shown
The 1.5 Max runout seems to be controlling the distance of breakout edge of all "teeth" (sharp corner as Shrock stated) to be with in 1.5 of each other
- 2 likes
by mgarguiloI received a CMM report from a supplier that includes a diameter (ID) and runout measurement. The B/P requirement for the diameter is 8.450 +/- .002"....
07-26-2011, 11:32 AM -
by NetterWe are trying to correlate the runout of a OD back to an ID using the CMM and indicator. I printed the text analysis of the runout for every point taken....
11-03-2008, 01:12 PM -
by AuRulesWith help from you guys on my earlier thread, we went with runout.
So I used this example
The worst circular runout...-
04-23-2008, 04:31 PM -
by JoBLOCKRoughly speaking: runoutx2 = concentricity right?
Example. round part. I am chucking on the OD checking the runout of the ID
03-30-2009, 02:55 PM -
by JoBLOCKOk, I have a rod with 2 dia.
The callout is on the 2nd dia. total runout .001 -A-
When I place the rod in the v-block on -A-,...-
02-23-2010, 10:48 AM -
