To start off I'm this is my first post and I'm new to CMM. On my Romer arm the Styli keeps coming loose. What is the proper way to install a new/ replacement styli tip? Is Loctite 222 acceptable? And is there a tool to tighten the styli down with? Any suggestions would be greatly appreciated.
Loctite on Styli?
Originally posted by Wes Cisco View PostDo not use a thread locker.
by Ken8282I am looking to get a new styli with 4mm by 75mm carbon fiber stem. Having never used carbon fiber stems before. Is there any special care they need?
02-25-2013, 10:05 AM -
by Sl33stakI need to order some new styli for our Gage2000 stand up CMM. The previous dept. head used to order 4x50 ceramic shaft styli. The size is great for what...
03-08-2006, 11:26 AM -
by AmberI'm wondering how tight the styli should be when it is attached to the probe head, some people in the shop use a paper clip to tighten it while others...
11-12-2013, 07:56 AM -
by The DudeWhere do you guys buy your styli? I am looking for a .5mm probe x 20mm (with an ML1 of 12mm) and am wondering if there is a place that y'all use
03-11-2010, 10:43 AM -
by DeWain HodgeI want to add another styli to an existing 5-way. Currently it has a Ø2mmx20mm styli the is pointed to 'Y' minus when the probe is at A0/B0. I want...
10-16-2014, 02:36 PM -
