How can I add a reference dimension to the report without having a plus or minus tolerance? What I mean is, I don't want to see +0.0000 and -0.0000 all I want to see on the report is the actual measured dimension, the nominal and how far it deviates. and no matter how far the measured value is from the nominal that the report shows it as acceptable (GREEN) even if its off by a mile.
Would I have to change the report and not show the +TOL, -TOL, and OUTTOL for reference dimensions every time or is there something simpler? Turning these on and off each time I have a reference dimension is like work. Even when I remove the extra stuff it still shows as red in color, Engineers do not like the red color, how do I change it to green, would I have to put a +/- 1,000 inches?
When using Calypso it is as simple as not putting a checkmark in the +TOL and -TOL sections. Does PC-DMIS have something as simple as that?
