Hi all,
I'm aligning my z axis to a plane which I'm taking four hits on, but when i press my probe onto the plane after I've done the alignment, the z co-ordinate is displaying as something like -0.8, anyone have any suggestions as to why?
Code being used for my alignments is below, the 1.5mm offset in the alignment is to account for the diameter of the 3mm probe and I have played around with that offset without it solving the issue.
Thanks.
Thanks.
STARTUP =ALIGNMENT/START,RECALL:USE_PART_SETUP,LIST=YES ALIGNMENT/END MODE/MANUAL FORMAT/TEXT,OPTIONS, ,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,DEV,OUTTOL, , LOADPROBE/3MM TIP/TIP1, SHANKIJK=0, 0, 1, ANGLE=0 LOADPROBE/3MM TIP/TIP1, SHANKIJK=0, 0, 1, ANGLE=0 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Take diagonal plane on RHS of jig PLN1 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<509.224,156.482,48.9>,<-0.125098,0.8082573,0.5753874> ACTL/<577.07,126.918,50.23>,<-0.0916386,0.8124672,0.5757599> MEAS/PLANE,4 HIT/BASIC,NORMAL,D=0.001,<604.163,151.389,76.691>,<667.044,121.747,71.85>,USE THEO=NO HIT/BASIC,NORMAL,D=-0.001,<423.74,119.16,82.746>,<488.67,92.052,85.358>,USE THEO=NO HIT/BASIC,NORMAL,D=0.001,<416.385,164.014,18.132>,<493.7,136.727,23.121>,USE THEO=NO HIT/BASIC,NORMAL,D=-0.002,<592.606,191.365,18.033>,<658.867,157.146,20.59>,USE THEO=NO ENDMEAS/ COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Take 6 point upper cylinder on jig CYL1 =FEAT/CYLINDER,CARTESIAN,IN,LEAST_SQR THEO/<546.287,-62.41,183.911>,<0.9876915,0.1563585,-0.0041885>,19.971,29.218 ACTL/<601.58,-92.66,183.68>,<-0.9933056,-0.1154184,0.0047595>,25.974,30.984 MEAS/CYLINDER,10 HIT/BASIC,NORMAL,<558.917,-50.658,186.483>,<617.742,-100.729,175.19>,USE THEO=NO HIT/BASIC,NORMAL,<559.929,-58.641,193.709>,<618.428,-103.291,187.133>,USE THEO=NO HIT/BASIC,NORMAL,<562.137,-68.982,188.245>,<616.007,-92.229,196.534>,USE THEO=NO HIT/BASIC,NORMAL,<533.298,-73.683,188.071>,<613.963,-78.901,187.957>,USE THEO=NO HIT/BASIC,NORMAL,<533.399,-65.693,193.879>,<615.08,-80.767,175.642>,USE THEO=NO HIT/BASIC,NORMAL,<531.819,-55.156,187.25>,<585.015,-84.672,175.277>,USE THEO=NO HIT/BASIC,NORMAL,<558.917,-50.658,186.483>,<585.753,-83.072,190.059>,USE THEO=NO HIT/BASIC,NORMAL,<558.917,-50.658,186.483>,<588.836,-93.926,196.725>,USE THEO=NO HIT/BASIC,NORMAL,<558.917,-50.658,186.483>,<589.422,-104.991,190.904>,USE THEO=NO HIT/BASIC,NORMAL,<558.917,-50.658,186.483>,<588.693,-106.412,179.227>,USE THEO=NO ENDMEAS/ COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, Take four point plane on front of cyclinders PLN2 =FEAT/PLANE,CARTESIAN,TRIANGLE THEO/<574.76,-127.376,126.517>,<0.9872258,0.1592475,-0.0050448> ACTL/<628.717,-161.937,127.784>,<0.9932954,0.1155731,-0.0026697> MEAS/PLANE,4 HIT/BASIC,NORMAL,D=0,<564.092,-59.248,190.883>,<620.561,-90.345,192.206>,USE THEO=NO HIT/BASIC,NORMAL,D=0,<563.753,-57.498,176.84>,<621.255,-96.602,179.847>,USE THEO=NO HIT/BASIC,NORMAL,D=0,<585.805,-197.39,76.318>,<636.531,-230.257,77.155>,USE THEO=NO HIT/BASIC,NORMAL,D=0,<585.39,-195.367,62.025>,<636.523,-230.545,61.929>,USE THEO=NO ENDMEAS/ A1 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES ALIGNMENT/LEVEL,ZPLUS,PLN1 ALIGNMENT/TRANS,ZAXIS,PLN1 ALIGNMENT/TRANS_OFFSET,ZAXIS,1.5 ALIGNMENT/LEVEL,YMINUS,PLN2 ALIGNMENT/TRANS,YAXIS,PLN2 ALIGNMENT/ROTATE,XMINUS,TO,PLN2,ABOUT,ZPLUS ALIGNMENT/ROTATE_OFFSET,90,ABOUT,ZPLUS ALIGNMENT/TRANS,XAXIS,CYL1 ALIGNMENT/END
