Pc-Dmis on Leica Laser Tracker
  • Pc-Dmis on Leica Laser Tracker
    I'm looking to find out if there are very many of you using PC-Dmis to do probe work with you Leica Laser Trackers? Does it work like PC-Dmis on the arms for probe work?
    I don't personally run that, but we do have a Leica Laser using PC-DMIS. Yes, it runs the same as a Romer.
      Actally, I use Polyworks, but I'm going to install PC-DMIS on the tracker... Wait and see...
        We do, i find it a bit annoyin...crashes, alignment, measurement from holes. i prefer Metrolog for Lasertracker work.
          The major difference is going to be interfacing with the controller and the probing but it's the exact same software for all types of hardware so if you're familiar with PC-DMIS for portable arms then it should be an easy shift to go to PC-DMIS on the Leica.
          Systems Integrator
            I have been using PCDMIS on laser trackers since 2007, and I will tell you that it works very well on some aspects, but it seems to crash a bit more than other software's that I have used with portable equipment.
