Re-take points
  • Re-take points
    Hello
    I'm farily new to PC-Dmis, using a romer arm atm.
    How do i re-measure something after my program is done and the report generated?
    I have highlighted the elements that i want to remeasure and chosen "execute block".
    And everything seems to work, but when the run is complete, the report is blank and the values seem to be the same as before.
    What i'm i not doing right?
    Thankful for help.
    In the report window header, there is a button called "View Report Mode" and one called "View Last Execute Report Mode".
    Try hitting one (View Report Mode).
    PC-DMIS has a built in that will only show what you last ran. So, if you last ran the whole program, that's what it shows. If you last ran a block of the program, that didn't include a dimension, then there's no dimension last executed to show.
      It does not seem to change anything, i'm afraid.
      Should the start and end lines of the program be included when you execute blocks?
      I just highlight the elements i want to remeasure when i do it now.
      • VinniUSMC
        VinniUSMC commented
        If View Report mode didn't work, then the other one (View Last Execute Report Mode) should.
      If you unmark the dimensions you want to re measure it should also unmark the features related to those dimensions then just execute the program not block so it will re execute the features and dimension that are unmarked.
      sigpicSTANDING CORRECTED IS THE ONLY WAY I STAND
        Thanks for answers, will try it out when i come back from my vacation.
