Copy one program to another Program
  • Copy one program to another Program
    How do you copy a section of a program to another Program?
    Open both programs , select the block you want , copy , go to other program paste where you want.
    Be carefull when running though , eg. Alignments ,planes, probes etc.
    Coot
      That sounds too simple...
      running 3.5 here, and im oder to copy & paste from one prg to another i have to
      1.) Place "RECALL/STARTUP" at the very end of the "copy"-program.
      2.)Copy features, and paste them below the RECALL/STARTUP in the same "copy"-program.
      3.) Cut and paste these points ( I usually "F3" prior to be able to id them in the new prg.) Paste them in the "PASTE"-prg at the BEGINNING after STARTUP.
      4.) Now cut and paste them where you need them
      BEWARE, you need to re-identify your ALIGNMENT/RECALL
      and be sure not to have copied any features or alignments with the same id.
      If everybody focused on the more inportant things in life, there would be a shortage of fishing poles!
        That garbage with the alignment you are doing is due to the fact that with V3.5 they changed the way the nominals of features are 'stored'. Pre V3.5, they were actual, hard values. Now, it is more like they are variables relating back to the alignment and to the machine numbers. So, if the 2 alignments are NOT the same, the numbers change. If you have V3.2063 on the computer, save=back to that version and try it there. I never had a single nominal change when copy-paste between programs until I went to V3.5.
          That is true,
          I remember the "good ole days" of simpler copy & pasting....
          But... as you so well know, where there's a will, there's a way.
          We all seem to have found work-arounds for problems we encounter.
            Try this: Check "Ignore CAD to Part" in both programs, then copy and paste the sections you need. If this box is left unchecked, the pasted features will change because they will relate to the alignment from which thet were copied.
            This works in v3.2063, may be worth trying. HTH
            v2013 MR1, v2015.1
            B&S Global 544, 555
            Mitutoyo A504 w/PC-DMIS
            Since 1994
            (Advice from my dad.)
