I would like to extract the hit points from a feature, like say a plane with 4 points. And use these 4 points for other feature construction. Is this possible?
Using hit points
Yes.
Either by extracting the hits and create vector points out of them (see the code section for the "to points" script by me) or by directly referencing the hits in the feature you construct, ie. PLANE1.HIT[1] for the first hit from the feature called PLANE1. There are more threads dealing with this in the PC-DMIS for CMMs section.PC-DMIS CAD++ 2o22.1 SP2
This is a good place to point out the value of using individual points and then constructing features from those points.
I do this with most of the features I use (a notable exception is auto-circles).
I just point and click auto-vector points and then those can be used to construct almost anything.Lately, it occurs to me
2017 R1 (Offline programming)
by c_beardenI can't seem to find an answer to this question so I thought I'd ask here....
I would like to pull Individual points from an exisitng feature and...-
11-05-2010, 08:56 AM -
by thecootK ....I have been taking Auto Circle features on a part and have had no problem (like the bottom pic, straight forward , 4 points , no problem). Now everytime...
04-19-2006, 11:18 AM -
by BSchwarkI,ve done it before but cannot get it to work now? I am doing an 8 point auto-circle and wish to extract the points individually and report them as a...
09-08-2006, 12:23 PM -
by RmhowardI am measuring a cross section without a CAD model to Reverse Engineer a bearing profile. I need help getting the PC Dmis Line code to take all of the...
05-01-2013, 11:46 AM -
by QuickStickzI have mid-point geometry that was created from actual points collected from either side of a feature. I need to report it to the nominal theoretical...
Channel: PC-DMIS NC
01-27-2020, 01:29 PM -
