Has anyone added a different size tip using PC-dmis and the romer hard probes. Since I am using an existing romer hard probe body, I turned off the auto probe detection box. I then copied a probe file in both the cimcore\winrds\calibrate\probe.dat , armdata and armdata.s6x folders. I also added the new probe file to the PC-Dmisw\ romer 5028- 168 files. I then calibrated the new tip in the cimcore Arm utilities. Now I amtrying to figure how to get the new probe in pc-dmis at the load probe file command in dmis. This is usually done by selecting (building a tip) from the dropdown selections. IE (PH-10, or tp-2,ect) With the roamer, these files are not there? I,m searching in the probe.dat files for the ones that I have, to copy and edit them!!!
Adding a new tip Romer/pc-dmis
Here is text, cut directly from PCDMIS' interfacing manual...
"Custom Probes
Romer’s power probe, Renishaw touch-trigger probes, and custom probes (usually probes with internal IDs 4 to 6) are supported through specific probe files that the user must create.
For power probe, the file name should be ROMER_POWERPROBE.
For Renishaw touch-trigger probe, the file name should be ROMER_RENISHAW.
For other custom probes, the file names should be ROMER_PROBE4, ROMER_PROBE5, or ROMER_PROBE6.
Since WinRDS compensates for probe lengths, only the diameter of the probe is needed for correct measurement in PC-DMIS. The length of the probe is used mainly for display purposes."
Hope this helps.
Stu
by 3dcmmOn a 6 axis absolute arm is it possible to calibrate and use a probe that doesn't have the electronics working in it?
Is there a way to...-
Channel: PC-DMIS Portable
10-30-2012, 01:33 AM -
by BlueRayWe're running a Romer Absolute arm 7535, and are currently shopping some new tips. My question is whether or not there is a simple way to change the tips...
04-03-2013, 12:51 PM -
by mdoggSo one of my current probe bodies has a 3mm x 10mm probe tip on it. I have some 3mm x 15mm probe tips that I want to install onto this same probe body....
10-12-2011, 09:33 AM -
by metalfabpmusing infinite arms 1.0 & 2.0 pc-dmis cad 4.3 looking to purchase 60 deg & 90 deg x 150 mm carbide point & ruby tip probes anyone using these....
09-24-2010, 11:15 AM -
I bought two new probes and discovered that they are not listed in the probe utility box. How can I add them so I can use them.
04-25-2014, 07:04 AM -
