PC-DMIS vision
  • PC-DMIS vision
    Using an Optiv 543. I need to measure (scan) an edge to evaluate profile using the
    camera. I created a curve using the clipping plane, when I open the "Auto profile
    2d" and select the curve, I get the whole curve. I only need a small segment of the
    curve. How do I select just the segment I want?
    I would try a linear open scan, or free form scan...
      I tried that, with the camera activated, those options are greyed out. Must be for tactile only?
        Please correct me if I'm wrong, but AFAIK, "profile" has a lot of other names too (such as runout, maybe even circularity? [Or am I mistaking that for form?])
        Try a couple different options.
        You say you created the curve already?
          regarding your Auto Profile 2D issue, check here: post #9. Might help.... might not.
          https://www.pcdmisforum.com/forum/pc...n/435210-curve
          BTW? Why post this in Planner AND Vision???
          Heh! 'Curve' !! UKCHAMP.... your Zeiss is showing!!
