is there a way to import nominal points to compare actual points to?
  • is there a way to import nominal points to compare actual points to?
    I have mid-point geometry that was created from actual points collected from either side of a feature. I need to report it to the nominal theoretical center points but when I bring in the nominal points to PC-DMIS it won't let me pick that geometry to create the nominal point. I have a couple hundred points I need to do so I don't want to type them in. How can I do this?
    If you've programmed to the correct nominals for the hits, the constructed midpoint will have the correct nominals, you won't need external data.
