I have a PC-DMIS program and I want two separate reports from the same program. I use the report command / print command to get two separate reports but only the first one has the standard PC-DMIS header with the program name, time, date, ect. on it. The second report has all of the required information just no header. How do I get the header that records program time, date, and name on the second report?
Printing multiple reports out of PC-DMIS NC from same program with headers for both?
by Donald MHi guys as the title suggests
after I run my program it prints out 2 reports, the first one with all the goodies, the 2nd one everything...-
10-06-2021, 11:56 AM -
by RHOELHi all! I've got a program that loops to measure four parts on one run. The program loops properly and gives me four separate reports except after the...
04-20-2016, 04:41 PM -
Hope this is an easy fix. I have a program set in a loop. I'm saving reports to a file just prior to the loop end. The problem...The first report saved...
06-22-2015, 12:15 PM -
by mdconI'm writing a some programs that will be using a loop to measure two parts on 2 different fixtures. I'm using FORMFEED to get the results for each part...
01-10-2008, 09:10 AM -
by awarzec1Hey guys, is there a command to add the date the program was created into the report header?
04-02-2015, 01:42 PM -
