I am trying to print .pdf files to a path on my PC. This was working fine but now even though the path in the dialog box is as I want it the print function ignores the path adds it to the file name and always places the report file in the same folder I was using. It's not a default PC DMIS folder so somehow it appears that it thinks a folder I have specified is now the default and it ads the path to the front of the file name as a name and always creates the file in the same folder. Any ideas?
Problems with report window print set-up
by Mranaskwhello guys
we have just loaded our programs into new pc everything works fine except that when the measuring is done the "do you want...-
06-15-2019, 12:04 PM -
by krupisI am using PC-DMIS v3.25. How can I find out folder path, where PC-DMIS saved report? Exists any parameters for this? I would like to create VB Script...
Channel: PC-DMIS Code Samples
02-11-2009, 08:58 PM -
by VONDYHello ,
I am looking for a code, macro, or script that would allow me to change a portion of the path in the "Report Print Options"...-
11-13-2013, 02:10 PM -
by A DishoPlease, help me to figure out .what is going on ,I am working on other person cmm,he left the job , he is runing 3.7 , when i write and excuting the...
05-26-2006, 09:14 PM -
by cappelThe default file setting in the "Edit Window Print Setup" box is to the folder that the program came from. When I change the folder that it...
10-10-2006, 09:23 AM -
