CMS CNC Machine with pcdmis
  • CMS CNC Machine with pcdmis
    I have been using pcdmis on a Romer Arm for years but just got a job at a shop that has it on a CNC machine. Since I’ve only used it with a Romer Arm, I’ve never had to program move commands or alignment in relation to a machine. No one that I work with can tell me where or how to program alignment to the machine or the probe movement commands. Anything would help.
    Are you referring to the CNC machine as a CNC CMM (Coordinate Measuring Machine)?
    PCDMIS 2015, 4.5.4 SF CMM, Datapage+5.0
      I was under the impression it was one of those CNC machines that can take points as it drills holes or whatever and make offsets in real time.
      Good question; which is it? :P
        Well this is the NC forum. from what I understand, its just like programming a CMM. Create a program and it turns it into g-code for the cnc machine to understand. We almost got if for a few CNC mill turn centers but we didn't go through with it.
          Do you have NC server, or NC Interactive? There's quite a difference.
          We use NC (not interactive) on a handful of parts.
          Either way, there's a seat of pc-dmis somewhere at your place that you'd use to program moves and alignment commands.
