true measure versus legacy
  • true measure versus legacy
    can someone explain the difference between these two types of measuring?
    should they produce the same results.customer has parts that measure good in true measure and bad in legacy.
    there true measure results match our results with legacy within a .0001.
    thanks scott
    The two types of reporting will produce the same results if the options are selected appropriately in each.
      If you want to use modifiers on datum, legacy doesn't work.
        Modifiers do work in legacy.
        Sent from my iPhone using Tapatalk
        Negative, Ghostrider...the pattern is full...
          Just double checked this. If modifiers are applied to datum, the legacy mode calculates TP wrong.
            Legacy has been working for me. It's the Xact Measure that has the bugs. I'll do some research to see if I can duplicate what you're seeing, nano
              Thanks. I was searching the same information since many months. Thanks for your hard work.
              SEO Company
              nursing assignment help
              SEO Freelancer
              empire carpet installation
              Band Scrims
              SEO
              SEO Freelancer
              carpet installation nyc
