Pcdmis NC & 4rth Axis
  • Pcdmis NC & 4rth Axis
    I need to know how to create a program using a 4rth axis in PCDMIS NC?
    Thanks in advanced.
    Sorry, can't help.
    I found a work around though. I added features to the fixturing that allow me to re-zero, after I rotate. These are calibrated features to the centerline of the rotary. So after measuring the calibrated features (a flat and a bushing), I run a part program for that side of the part. I typically have 4 to 8 programs, depending on the complexity of the part.
    If you figure it out, let me know. I may have some time soon to experiment. I will soon get a few parts for which I can not do my tried and true trick.
    Jan.
      It depends what type of axis you are referring to. If it is a rotary table, you need to have this option on your portlock. If it is a swivel head for example you need to change the configuration of pc-dmis NC to allow the programming of these angles. What type of machine / interface do you have? - Jon
