PCDmis Gear reports the space thickness for inside gears. Is it possible to change this to report tooth thickness for inside gears instead?
Tooth thickness/space width inside gear
by ACM1970Has anyone ever measured involute sprockets with the Gear software package. THe issue I am having is that the pitch diameter of the involute sprocket...
Channel: PC-DMIS for Gears
11-01-2007, 10:36 AM -
by kmcmmWhat is the best way to offset for material thickness?
TIA-
06-13-2006, 03:08 PM -
by alin2216hello.run program PC-DIMIS CAD+ + 2010 MR3 and codes should not be cleared when the bag material thickness of an item and you do not have plugged.for...
05-24-2013, 02:52 AM -
by John Riggins
Is this not double-dimensioned?
Or is it a special control?-
09-18-2007, 08:26 PM -
by SoberYangHi All
Does the PC-DMIS Gear support DIN 5480?
If yes, Could anyone tell me how to make that?
Thanks all.-
06-25-2012, 12:50 AM -
