Default "New" Program
  • Default "New" Program
    This may sound like a n00b question, but is there a way to set what lines show up at the beginning of a program when you start a new program. I have worked at a number of shops and they are all different, so it stands to reason that it must be able to be set somewhere. I do NOT want a default program that I open then "Save As". Thanks in advance.
    sigpicYou're just jealous the voices talk to me.
    SAME HERE DIFF EMPLOYERS DIFF SET UP. A stab in the dark maybe somewhere in the settings editor
      The system parameters etc? They can be set using the Default button in the setup and/or parameters.
        Will that put code into the program every time?
          I also want to add some comment lines to every program, but if this is not a template type thing I think I am SOL.
          I used to use MeasureMax and it had a template program that it used when you clicked on the new program button.
          Alas, I think that I will just have to get in the habit of copying and pasting the comments.
            I have a master Template program I use whenever I start a new program.
            Lately, it occurs to me
            2017 R1 (Offline programming)
              You can only default system parameters. If you want comments you'll have to use a new program template.
                On the Custom Script Repository, there's a VB scripting example I created a while back that runs within excel. Based on what you fill out, it automatically populates the new part program with tracefields. I imagine you could use this as an example of how to work up something similar for your needs.
                http://www.wilcoxassoc.com/perl/secu...ramcreator.zip
                  Well, at least I have the parameters the way I want them. Thanks guys.
                  SCROLL LOCK
                  ROOT BEER
                    If you put in a master program what ever you want.
                    You can save it.
                    open it.
                    save as the program name you want.
                    then write your program and save.
                    Your master program will still be there for the next program.
                    There might be another way. I will need to check. but for now it is one way.
                    THANKS (CAD IS ALWAYS MASTER)
                      You can save it.
                      open it.
                      Good idea, but I already said I do not want to do that.
                        I Am At Home Right Now. I Guess I Did Not Read It All. I Will Check Monday When I Go Back To Work. I Do Not Remember Any Way Of Doing What You Want. But I Am Sure With All The Good Programmer Here, They Will Think On It.
                          Jared...you put a link to a "secure" area that needs a user name and password
                          Starrett RGDC 4028-24 :alien:
                            works with basic-script
                            my way of an Default Program:
                            - originally i created a program the way i liked it
                            - then i exported it in basic-format (.bas)
                            - that .bas-file i altered with an editor (deleted the first commands)
                            - create an icon on the toolbar for executing that basic script
                            so for each new job i create a new program in PCDMIS,
                            put the cursor at the end of the code and hit the toolbar-button
                            for the basic-script, so the program gets populated with the
                            necessary code.
                            See the attached sample-script.
                            HTH
                            StartWithCreatingVars.zip
                              Right. This is the password protected Custom Script Repository. All you have to do is register at the WAI website if you don't already have access. You can quickly and easily register here:
                              http://www.wilcoxassoc.com/Usersarea/login.htm
                              Once you confirm registration, you will be logged in and can download others' scripts or share your own.
