Graphics question
  • Graphics question
    After running for several hours the highlight function get "delayed".
    Normally, when picking a CAD surface with the mouse the surface will highlight. After I have had pcdmis open for a while and I pick a surface it will not highligh untill I "drag" the CAD. Everything else seems to be working ok.
    If I shut down pcdmis and re-open the same (or any other program) the highlight function goes back to normal. Running an offline seat.
    Any clues?
    (yes I have installed the "hotfix")
    Lately, it occurs to me
    2017 R1 (Offline programming)
    Maybe a corrupt file or files. Shut down the demon and delete the "executebarstate.dat" and "gbarstate.dat" files and restart. Then try again.
    sigpic GDTPS - 0584
      sounds more like Pcdemon constipation. Big cad file? Big program?
        This has to be a demon glitch....I have 3.7 mr3 and my graphics display will white out, until I move the graphic or resize. I just learned to deal with it.
        AS for teh file size, this does not seem to be a contributing factor.
        A.Gore
        sigpicA.Gore
          I do not know if there is a fix yet But when I upgraded to 4.2mr2 my debug file will keep growing in size all by itself. It has got up over 30mb before, so I keep a check on it and turn off PCDMIS every now and then. When I asked about it I was told that is something they have noticed with the upgrade. I do not know If you have the same problem. take a look. Right now I live with it.
          THANKS (CAD IS ALWAYS MASTER)
            Where does one find the debug file to check it??? actual name and ext.?
            sigpicThanks a Millionth
              It is in your 4.2 foldier or 3.7, which ever one the program is running from. It is called debug and is a text file.
                Appreciated
                  Don't have either of those files.
                  Happens with both large and small CAD files and programs.
                  A.Gore
                  Yeah, I have the "white-out" problem also, but that is easier to live with.
