Run Only Programs
  • Run Only Programs
    Hi there,
    I have over 700 shopfloor programs and 3 CMM's.
    The problem I have is the programs are always 'live'.
    Any Tom,Dick or Harry can use them and unknowingly alter a program.
    Is there a setting that I can activate that allows just 'run program' access to all my programs without 'error messages' and 'save as' appearing on the screen.
    I having tried educating operators to use the 'Quit' button but to no avail.
    Any help would be appreciateed.
    Cheers Lee.
    try operator mode use C:\PCDMISW\PCDLRN.exe /o to start program
      This is one of the bad things about PC-DMIS. Run them in Operator Mode as Tom pointed out or make the programs "read only" When the operators try to close a program it will prompt them to save as another file name. Then it is cancel or save it as another file name.
      We have approximately 300 programs that get run regularly and over 1500 in the folder system on the network. Only once in a great blue moon do things not go right. Back ups, back up, back up.... the only way to cover back side.
      Duane
      Contura Calypso 5.4
        How about marked sets? Operators will only have access to the icons created.
        And lock them to prevet anyone from modifying.
        sigpicIt's corona time!
          I am in the same situation. I use the operator mode and all is fine. In order to use the operator mode and not get "Save as a new name" your permissions have to be set correctly. Definitely back all programs up, including probe files.
          ________________________________________
          " I am a CMM programmer, not a magician."
          2011 MR1
          Global 9_12_8
            There was a VB SUI (Stupid user interface) that could be downloaded. I have used it in the past and it worked great. I had to modify the VB code some what but it worked.
            Brain- Pinky, are you pondering what I'm pondering?
            Pinky- I think so, but where will we find an open tattoo parlor at this time of night?
              It is still on the Wilcox site.
              AllGUI.ZIP
                Same situation also, running 4.1 on all the shop floor CMM's. The only problem w/ "operator mode" is you cannot view the probe calibration results in operator mode. Has anyone else noticed this or is this a problem w/4.1? I use "marked sets" then flag all shop floor programs as read only. Have not had any problems w/ "the monkeys" since.
                  I store all of the "Master" programs in special directories that only I and administration (read IT) have access to.
                  Lately, it occurs to me
                  2017 R1 (Offline programming)
                    I DON,T KNOW IF THIS WILL HELP.
                    Assuming you have purchased the necessary modules, and your port lock is properly configured,
                    you can launch PCDMIS
                    in different configurations. To do this,
                    1. Access the directory where the PCDMIS
                    executable shortcut is located (generally this is
                    located at C:\Documents and Settings\All Users\Start Menu\Programs\PCDMIS
                    for
                    Windows).
                    2. Rightclick
                    in the directory and select New | Shortcut.
                    3. Follow the onscreen
                    instructions to have the shortcut point to where the PCDMIS
                    executable, pcdlrn.exe, is located (wherever you installed it).
                    4. Add any of these command line switches (or arguments ), following the shortcut's full
                    path to the executable:
                    /f for offline mode
                    /u for user privilege level when you are logged onto the system as an administrator
                    /o for operator mode
                    /r for reverse axes mode on the slave arm of a dual arm system
                    /p for pro mode (cannot use with /c switch)
                    /c for cad mode (cannot use with /p switch)
                    Wilcox Associates, Inc.
                    14 · Getting Started: An Overview PCDMIS
                    4.2 Reference Manual
                    /d for debug mode for this session
                    /nc0 to run PCDMIS
                    without the CNC functionality
                    /5unique to run PCDMIS
                    without this functionality
                    /cmt to run PCDMIS
                    /dccscanning to run PCDMIS
                    /displaycad to run PCDMIS
                    /laserprobe to run PCDMIS
                    /masterslave to run PCDMIS
                    /nocontactprobe to run PCDMIS
                    /remotepanel to run PCDMIS
                    /rotarytable to run PCDMIS
                    /sheetmetal to run PCDMIS
                    /statsoutput to run PCDMIS
                    /systemv to run PCDMIS
                    /toolchanger to run PCDMIS
                    /valisys to run PCDMIS
                    /vision to run PCDMIS
                    /wrist to run PCDMIS
                    So if you want to run PCDMIS
                    pro in offline mode, the target location would look
                    something like this:
                    "C:\Program Files\pcdmisw\PCDLRN.exe" /p /f
                    You can also tell PCDMIS
                    to automatically open a specific part program (or part
                    programs) by appending a pathway string pointing to a part program as a command line
                    argument.
                    · When specifying a part program to load, however, you do not need the / character
                    required for the other arguments discussed above.
                    · To open more than one part program, type a space between each additional pathway.
                    · If your filename contains spaces, put the pathway within quotation marks.
                    THANKS (CAD IS ALWAYS MASTER)
                      There is another alternative that I have not seen mentioned in this thread.....STI. STI (Single Touch Interface) is an add-on module to PC-DMIS that does basically the same thing as the interface that cmccullough mentioned. It gives the operators a menu screen and allows them to click buttons to run your programs. Using STI does not allow modifications to your PC-DMIS programs. You can also use it to display your data in a sort of Power Point slide show. This can also benifit the operators by allowing them to know at a glance whether their parts are in spec or not (versus decipering a report). We have 3 cmms and use STI on our 2 shop floor units. It is working great!
