I cant get rid of this error .... what can i do?
X-axis chip rate error
You may have a bad encoder, but more likely just some debris on the scale. This can be cleaned with alcohol on a cotton swab. With the E-Stop pressed, push the Z all the way to one end of the bridge and wipe the scale with alcohol-soaked cotton swab from center out a few times til the swab comes up clean Push Z to the other end and repeat the process. Make sure the encoder is riding properly in its track and not slip-sliding around. Re-initialize the controller and home the machine. If the error is still there, the encoder is probably toast.
HTH
Edit: A little fast on my response, saw the other responses after I posted this.Last edited by Don Meredith; 05-30-2006, 03:22 PM.v2013 MR1, v2015.1
B&S Global 544, 555
Mitutoyo A504 w/PC-DMIS
Since 1994
(Advice from my dad.)
by amarkoI cant get rid of this error .... what can i do?
05-30-2006, 08:15 AM -
by RuhRohWe have a microxcel pfx using PCdmis, We mainly use it for occasional dimension checking on prototype units. I have been trying to track down a problem...
09-12-2007, 05:09 PM -
by Erikirbrown & sharpe cmm one
pcdmis CAD++ 2011 mr1
I had the error pop up once yesterday and had to turn the cmm off and on to clear...-
01-15-2013, 02:07 PM -
by djone368does anyone know what causes a chip error
is this something I can fix or do we need to get the B.+S. guy in
thanks
Dave-
12-07-2006, 10:00 AM -
by #2#I keep getting watchdog fault - x-axis custom chip rate error.
I know that this is most likely caused by a dirty x-axis scale. I am going...-
08-11-2006, 09:53 AM -
